wont start im clueless??????
Old Jan 4, 2004 | 06:07 AM
t3to4e's Avatar
Default wont start im clueless??????
i havve a 94 rs that i swaped a gsr into i have fuel and spark but my car wont start
Old Jan 4, 2004 | 07:04 AM
t3to4e's Avatar
Default Re: wont start im clueless?????? (t3to4e)
cranks but wont turn over
Old Jan 4, 2004 | 08:41 AM
ITR_1211's Avatar
double-check all ground connections
Old Jan 4, 2004 | 09:10 AM
t3to4e's Avatar
Default Re: wont start im clueless?????? (Darryl Musashi)
anyone else
Old Jan 4, 2004 | 09:24 AM
Jimmy's Avatar
Global Moderator
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Darryl Musashi &raquo;</TD></TR><TR><TD CLASS="quote">double-check all ground connections</TD></TR></TABLE>
excatly what i was gonna say
Old Jan 4, 2004 | 03:06 PM
t3to4e's Avatar
Default Re: wont start im clueless?????? (USDMDC2)
check any other ideas fuel spark and air
Old Jan 4, 2004 | 03:38 PM
katzenjammer84's Avatar
Could be anything man. I don't know.
Old Jan 4, 2004 | 04:44 PM
RCautoworks's Avatar
Default Re: wont start im clueless?????? (AcuraFanatic)
Check the compression, see what numbers your pulling.
Old Jan 4, 2004 | 04:47 PM
Dtuned's Avatar
Default Re: wont start im clueless?????? (90blackcrx)
check cam timing... firing order...
Old Jan 4, 2004 | 06:31 PM
t3to4e's Avatar
Old Jan 4, 2004 | 06:38 PM
Turbogixxer's Avatar
You need four things to start a motor: compression, spark, timing, and fuel. Recheck all your grounds and all your connectors.
Old Jan 5, 2004 | 06:57 AM
t3to4e's Avatar
Default Re: wont start im clueless?????? (turbogixxer)
well i guess ill have to take it to a shop
Old Jan 5, 2004 | 07:49 AM
xenocron's Avatar
is it chipped? if so, i just had a problem with my ECU fouling a chip...had to burn a new chip to get it to start.
Old Jan 5, 2004 | 09:41 AM
t3to4e's Avatar
Default Re: wont start im clueless?????? (xenocron)
as a matter of fact it is chipped shoud i try another ecu then
Old Jan 5, 2004 | 10:59 AM
Burke's Avatar
Banned
yea make sure your firing order and timing is good.
Old Jan 5, 2004 | 02:42 PM
t3to4e's Avatar
Default Re: wont start im clueless?????? (Burke)
the ecu is fine
Old Jan 5, 2004 | 03:28 PM
Burke's Avatar
Banned
are you sure your firing is correct. that's what it sounds like to me
Old Jan 5, 2004 | 07:33 PM
SYD's Avatar
SYD
From: Bluffton/Hilton Head,SC / Ft. Lauderdale, FL, usa
do u have any cels? and hows the timing?????
Old Jan 6, 2004 | 06:59 AM
t3to4e's Avatar
Default Re: wont start im clueless?????? (bruceleeroy)
i have s its 21 and 22
Old Jan 6, 2004 | 07:10 PM
SYD's Avatar
SYD
those are just vtec selenoid and vtec oil pressure..they will not prevent the car from starting...did u double check the timing?... or fouled plugs(since u said u have spark)..how long has the car been sitting old gas? any gas??
Old Jan 6, 2004 | 07:19 PM
t3to4e's Avatar
im just going to take it to a local shop
Old Jan 6, 2004 | 08:05 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 90blackcrx &raquo;</TD></TR><TR><TD CLASS="quote">Check the compression, see what numbers your pulling.</TD></TR></TABLE>
That sounds like a good idea, have you checked the compression yet ?
Old Jan 7, 2004 | 05:00 AM
jdmcx's Avatar
i think it is 180 degrees off if you want we can try doing it today
Happiest92Ricer
12
Jun 28, 2013 08:52 AM
kelviiv
Dec 17, 2008 11:19 AM
Spody02
12
Sep 9, 2008 10:16 AM
THE BULL
15
Jan 28, 2008 09:49 PM
Stray
Jul 5, 2007 12:33 AM
