hep with Barometric Pressure Sensor Circuit
Old Jan 3, 2004 | 09:44 PM
otakueric's Avatar
Default hep with Barometric Pressure Sensor Circuit
if the 'Barometric Pressure Sensor Circuit' cel code is blinking
how do you alleivate the problem? or what can cause the problem?
would he have to take the car to a honda guy or will the local mechanic know how to take care of it?
Old Jan 3, 2004 | 10:15 PM
otakueric's Avatar
ttt
please help
Old Jan 3, 2004 | 11:50 PM
otakueric's Avatar
i know it controls the air/fuel ratio and might cause my motor to run lean or rich but is it in the ecu itself? would i need to replace the ecu to fix it? let me know!
Old Jan 4, 2004 | 12:18 AM
zigs's Avatar
Default Re: (otakueric)
What ecu are you using? Has this ecu worked in the past with no codes?
Old Jan 4, 2004 | 12:31 PM
Cynical 1's Avatar
Default Re: hep with Barometric Pressure Sensor Circuit (otakueric)
Sounds like the MAP sensor. Yes, it will make your car run like ***...
No, it's not in the ECU, it's mounted on either the firewall, or the intake mani/throttle body. It will be a little black rectangle, and will be labeled MAP sensor.
If it goes bad, you must replace it.
Old Jan 4, 2004 | 03:48 PM
otakueric's Avatar
i was told that i dont have a MAP sensor if i have a BARO PRESSURE SENSOR...
so im confused?
Old Jan 5, 2004 | 05:09 AM
EE_Chris's Avatar
You have both the MAP and BARO sensors. BARO sensor is usually located inside the ECU, thus fixing it means replacing the whole ECU.
Do you have a VAFC or some other fuel controller?
Old Jan 5, 2004 | 08:17 PM
otakueric's Avatar
would a new ecu DEFINITELY fix the baro problem?
Old Sep 13, 2005 | 04:49 PM
BEEYOND's Avatar
no because no one knows where the baro sensor is for obd0.... obd1/11 are all in the ecu.....
tdub1904
Nov 2, 2009 07:32 AM
ZXRider
May 16, 2007 07:50 PM
bmoua
Apr 15, 2007 12:24 AM
Grandhustleman86
Mar 6, 2007 04:34 AM
Civic89
Jun 17, 2002 01:26 PM
