94 accord timing belt problem
Old Jan 3, 2004 | 09:12 PM
BoostedB20A's Avatar
Default 94 accord timing belt problem
Ok, we just changed a timing belt in a friend of a friends accord. The belt broke, we replaced it, and now the car skips at idle, but when you rev it, it dosnt skip. Any ideas?
Old Jan 3, 2004 | 10:17 PM
WuWarrior's Avatar
Default Re: 94 accord timing belt problem (BoostedB20A)
The accord is an 'interference' engine. If the timing belt breaks, the pistons will strike the valves. The valves are most likely damaged.
Old Jan 3, 2004 | 11:25 PM
Br1anPham's Avatar
Default Re: 94 accord timing belt problem (WuWarrior)
Correct.
Old Jan 4, 2004 | 12:16 AM
iam7head's Avatar
Default Re: 94 accord timing belt problem (Br1anPham)
run a compression test, the valve is properly bent or not in spec anymore.
Old Jan 4, 2004 | 08:22 AM
jwogen1's Avatar
if you threw the belt when it was running obviously, any of the valves that are open at the time will be bent. it happened to me in my first civic, 1st and 3rd were open and they were bent to ****.
Old Jan 4, 2004 | 08:54 AM
But if a valve was bent, wouldnt it not run at all? Or if it did run, wouldnt it skip all the time?
Old Jan 4, 2004 | 08:59 AM
ArchAngel Sabastian's Avatar
New User
pull the head not that hard and only way to know for sure, if no valves or bent (they probably are) but ive had 2 cars break belts while running and not bend valves, you most likely have the timing off somewhere thus **** idle but good threw higher rpms
Old Jan 4, 2004 | 09:10 AM
jwogen1's Avatar
Default Re: (ArchAngel Sabastian)
i have heard of no valves bending when a belt is thrown, so i would check into the timing. if they are bent you're right it probably wouldnt run at all, mine didnt
Old Jan 4, 2004 | 09:11 AM
jwogen1's Avatar
Default Re: (jwogen1)
sometimes they dont bend as bad as others and can still run somewhat, potentially skipping i believe
Old Jan 4, 2004 | 09:12 AM
New User
theres no way to know if the valves are bent or not so i wouldnt do anything till i pulled the head cuz if you dont youve just done a half assed job
AccordInTheMaking
Feb 11, 2010 06:08 AM
lsvtec2000
Jan 3, 2008 07:05 AM
streetskatr5268
Nov 15, 2005 07:04 PM
im_the_teacher
Nov 15, 2003 11:54 AM
HaTcH_BmX
Jun 1, 2003 03:57 PM
