JDM Door-panels Interchangeable With USDM?
Old Jan 3, 2004 | 08:16 PM
:jdmshmaydm:'s Avatar
Default JDM Door-panels Interchangeable With USDM?
If you get the JDM door panels could you switch them with a USDM Integra and just rearrange where the switches are? Basically not giving yourself the shaft if you buy these and having the master controls on the passenger side.
Old Jan 3, 2004 | 08:26 PM
MiraiZ's Avatar
Default Re: JDM Door-panels Interchangeable With USDM? (Gatecrasher20AF)
your switches will have to be on opposite sides...other than that...it should work
Old Jan 3, 2004 | 08:40 PM
Default Re: JDM Door-panels Interchangeable With USDM? (MiraiZ)
Well yeah, but I saw a pic and it looks like it has the switch already on it. Could you just remove them and re-install them to the other side?
Old Jan 3, 2004 | 08:52 PM
MiraiZ's Avatar
not sure if they are the same size
Old Jan 4, 2004 | 12:07 AM
Went outside and measured my switches length and they both came out to 5 3/4 inches exactly. Also approximatley 2 1/4 inches for the width of both switches.
So since they are indeed the same size, that would make taking the JDM door panels and switching the location of the switches theory work huh? w00t!
*Did you just conveniently have that picture of the comparison at your disposal? That was cool. *
Old Jan 4, 2004 | 12:53 AM
{Mineral Grey} ITR's Avatar
The Usdm passenger switch should fit with no problem, but the driver's side Usdm switch will not fit, wthout using a dremel. As illustrated in the picture above, the Jdm Driver side switch is made to fit for LHD. I compared Both USDM Drivers switches and JDM switches and the only thing I noticed different was the upper right slope(Jdm), compared to the Upper left slope(usdm) on both Housings.
Old Jan 4, 2004 | 02:17 AM
Default Re: JDM Door-panels Interchangeable With USDM? (IN-N-OUT (98 ITR))
So just use a dremel and you could get it to work? That doesn't sound like too much trouble if that's the case.
Old Jan 4, 2004 | 02:26 AM
Kicker773's Avatar
what exactly are the differences between the usdm n da jdm ones.. with the exception of the switches sorry ahd to ask
.hawaii
Oct 28, 2010 01:16 PM
inh
Sep 27, 2008 06:38 PM
EDoTdc2
Oct 16, 2003 06:06 AM
Turbo-JC
Audio / Security / Video
Jul 20, 2003 07:50 AM
acuraLSSE95
Sep 9, 2002 09:07 AM
