What ECU's are you guys using with your JDM B16a swaps?
Old Jan 3, 2004 | 07:21 PM
SadisticRacing's Avatar
Default What ECU's are you guys using with your JDM B16a swaps?
I'm just wondering what ecu's you guys are using with your JDM B16a motor swaps. I have a '90 Honda Crx running OBD0 and think my ECU is the wrong one. I have a PR4-OBD0 ECU right now!!
Old Jan 3, 2004 | 07:32 PM
biggdogg's Avatar
Default Re: What ECU's are you guys using with your JDM B16a swaps? (SadisticRacing)
you need a pw0 or pr3 . i have 2 forsale if yo uneed them .
Old Jan 3, 2004 | 07:34 PM
Default Re: What ECU's are you guys using with your JDM B16a swaps? (biggdogg)
How much and are they chipped or regular?
Old Jan 3, 2004 | 08:15 PM
SC0TT's Avatar
I ran a pw0 at first then switched to a pr3. You definately want to run either of those..not a pr4.
Old Jan 3, 2004 | 09:41 PM
biggdogg's Avatar
stock ecus ,150 shipped
some other stuff too
https://honda-tech.com/zerothread?id=721977
Old Jan 3, 2004 | 11:00 PM
Nerologic's Avatar
SC0TT., why did u swich from pw0 to pr3??
Old Jan 4, 2004 | 08:19 AM
Thanks for all the replys, I'll keep yours in mind but going to check for a chipped ECU from my local shop first!!
Old Jan 4, 2004 | 02:35 PM
Deetz's Avatar
Crazy Honda Guy
The pr4 is the 90-91 Intrgra non vtec B18A ecu and won't provide any actvation point for the vtec soliniod.
Old Jan 4, 2004 | 08:38 PM
Default Re: (Deetz)
Mine kicks into Vtec but it seems to me that it does sometimes and then sometimes it doesn't. I don't know how the guy that did my swap got it to work but that's why I want to just get an ECU that is for Vtec. I talked to a guy today and he's got a Pr3 chipped with the PYR program for sale for $200, is that a good price or not?
Old Jan 4, 2004 | 08:45 PM
Malgerus's Avatar
Default Re: (SadisticRacing)
Ran a Pw0, then a Pr3, and now I'm running a home-chipped Pw0 with a Spoon program.
Get either a Pw0 or a Pr3.
Old Jan 4, 2004 | 09:07 PM
Default Re: (Mr. S)
What's the difference between the Spoon/Mugen chips and the PYR chips? I know that the PYR vtec is 5200 and redline is 8800, so what are the vtec and redline on the Spoon/Mugen ones?
Old Jan 4, 2004 | 09:54 PM
91civicDXdude's Avatar
"spoon" "mugen" and other ebay chips are pure crap.
If you dont have a chip thats tuned specifically for your mods and engine, then you are probably better off advancing your timing all the way and raising fuel pressure a little bit, which is the equilvelant of those chips ( i realize the chip wouldn't raise fuel pressure, but almost all of those chips just advance the timing like crazy and raise the injectors pulse width duration)
Old Jan 4, 2004 | 10:52 PM
Default Re: (91civicDXdude)
So basically your saying that the ebay stuff is for the ricers who go for the name. That's what I thought so I'll just go with the one from my local shop for the $200 then.
Old Jan 4, 2004 | 11:05 PM
customx_'s Avatar
New User
having a "chipped" ecu means **** if your motor is stock.
Old Jan 5, 2004 | 12:53 AM
michael O's Avatar
I'm going to use a p30 ecu.
Old Jan 5, 2004 | 09:27 AM
Default Re: (skunk'dR34)
By "stock" motor what do you mean because I have i/h/e, 75 shot of nitrous. So should I just get a regular ECU or get a chipped one since I'll be getting my vavletrain done this summer.
Old Jan 5, 2004 | 10:30 AM
f@sth@tch89's Avatar
im using a pr3 chipped by ERE. according to ERE u have a few more options when reprogramming the pr3 than the pw0. pr3
reprogram the ecu if its going to be a track car.
Old Jan 5, 2004 | 10:32 AM
EL Vap133's Avatar
I have a PWO...
Old Jan 5, 2004 | 10:44 AM
Default Re: (fasthatch89)
I'm building this to be a drag only car!!
Old Jan 5, 2004 | 11:24 AM
Smokinsax's Avatar
The Boot
Default Re: What ECU's are you guys using with your JDM B16a swaps? (EL Vap133)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EL Vap133 &raquo;</TD></TR><TR><TD CLASS="quote">I have a PWO... </TD></TR></TABLE>
Old Jan 5, 2004 | 11:50 AM
Default Re: What ECU's are you guys using with your JDM B16a swaps? (Smokinsax)
Just got off the phone with my shop I go to and they said to go Pr3 for sure but it was up to me on the chipped or not chipped!! So just need to know if you guys think I should go chipped or not chipped now?
Old Jan 5, 2004 | 11:58 AM
(JON)'s Avatar
Default Re: (michaelOlson)
im using a pr3 ecu no problem.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by michaelOlson &raquo;</TD></TR><TR><TD CLASS="quote">I'm going to use a p30 ecu.</TD></TR></TABLE>
if youre going to use this ecu in an ef, you will have to swap everything to obd1 and run a obd0-obd1 jumper harness!
Old Jan 5, 2004 | 12:08 PM
michael O's Avatar
Default Re: (DaStyle)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">if youre going to use this ecu in an ef, you will have to swap everything to obd1 and run a obd0-obd1 jumper harness!</TD></TR></TABLE>
Yep. Need to in order to pass at the smog ref.
Old Jan 5, 2004 | 01:18 PM
SC0TT's Avatar
Default Re: (Nerologic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Nerologic &raquo;</TD></TR><TR><TD CLASS="quote">SC0TT., why did u swich from pw0 to pr3??</TD></TR></TABLE>
My swap came with a pwo originally, sent it to katman for chipping...he didnt have the program I wanted available for the pwo..so he traded me the pwo for a pr3. Sent me back a chipped pr3. No real functional or performance reason for switching.
Old Jan 5, 2004 | 01:34 PM
Default Re: (SC0TT)
So you would agree that pr3 is easier to program then pw0 also. Should I chip it or not?
