i think its time for the timing belt?
Old Jan 3, 2004 | 04:15 PM
green98civic's Avatar
Default i think its time for the timing belt?
when i was coming home from work i heard a metal to metal sound coming from the belt side. It was a squealing sound. it is a 88 crx si with 157,000 on the engine. so what could it be? and time for a new engine?
Old Jan 3, 2004 | 05:21 PM
Vinceg99's Avatar
Default Re: i think its time for the timing belt? (green98civic)
Do you have A/C?? If so check out your compressor and see if thats making the noise. If not check your alternator.
Old Jan 4, 2004 | 09:30 AM
Default Re: i think its time for the timing belt? (Vinceg99)
i cut the ac belt a long time ago. is it the pulleys? please help diagnose.
Old Jan 4, 2004 | 11:16 AM
tjbizzo's Avatar
Screw you guys, I'm... going... home.
Chech the tensioner pulley bearing on both the timing belt tensioner pulley and the accessory drive belt tensioner pulley. I had a bearing in a fan belt tensioner pulley fail without making a sound and I only noticed it when I smelled the burning rubber of the fan belt going over the frozen pulley.
mikey88
Apr 19, 2017 10:57 AM
2007430
May 2, 2012 06:22 AM
ramonjones16
Dec 7, 2009 06:35 PM
IP RACING
18
Sep 26, 2008 10:15 PM
