problems w/ crx...HELP
Old Jan 3, 2004 | 11:02 AM
SimbaDogg's Avatar
Default problems w/ crx...HELP
ok...somethings wrong w/ my car, and i have no idea what it is right now. right now, i can tell the car is running on three cylinders. it rained last nite, so i was thinking maybe some water got into the spark plug wire area, cuz there was water all over my motor when i popped the hood last nite. i pulled the plugs, checked all the wires, and everything seems like its straight right now. after i started up the car and let it run for like 15 min, the exhaust temp was still very cold. i was thinking maybe its the dizzy itself. does anyone know what i should check for right now, and how to go about checking for spark on each individual cylinder?
Old Jan 3, 2004 | 11:04 AM
crxgator's Avatar
Default Re: problems w/ crx...HELP (SimbaDogg)
to check for spark for each cylinder have a buddy crank the engine while you have the wire with the sparkplug next to something metal on your engine ...
Old Jan 3, 2004 | 11:18 AM
redeyeef2's Avatar
You should double check your wires at the distributor cap as well.
http://www.redeyefabrication.com
Old Jan 3, 2004 | 11:23 AM
SimbaDogg's Avatar
Default Re: problems w/ crx...HELP (redeyeef2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxgator &raquo;</TD></TR><TR><TD CLASS="quote">to check for spark for each cylinder have a buddy crank the engine while you have the wire with the sparkplug next to something metal on your engine ...</TD></TR></TABLE>
is that 133% safe?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by redeyeef2 &raquo;</TD></TR><TR><TD CLASS="quote">You should double check your wires at the distributor cap as well. </TD></TR></TABLE>
i already did
Old Jan 3, 2004 | 01:22 PM
SimbaDogg's Avatar
for 22 bucks, i tried going w/ a new cap n' rotor (needed to be replaced anyways) but yeah...it was the cap n' rotor, thanx for the help guys
Old Jan 3, 2004 | 01:41 PM
1's Avatar
Dry out the entire area under the distributor cap.
Old Jan 3, 2004 | 02:34 PM
SimbaDogg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SimbaDogg &raquo;</TD></TR><TR><TD CLASS="quote">for 22 bucks, i tried going w/ a new cap n' rotor (needed to be replaced anyways) but yeah...it was the cap n' rotor, thanx for the help guys</TD></TR></TABLE>
Old Jan 3, 2004 | 02:39 PM
1's Avatar
Sorry, I am getting old.
Old Jan 3, 2004 | 02:57 PM
SimbaDogg's Avatar
Default Re: problems w/ crx...HELP (1)
lol...no problem man. we all miss a post every once in a while
ZombiePharoh
Jan 20, 2014 09:28 PM
ZombiePharoh
Jan 20, 2014 06:47 PM
jdmsleeper12
Jul 27, 2009 10:54 PM
black cx
18
Nov 28, 2004 01:05 PM
