Switching Exhaust housings on two turbos??
Old Jan 3, 2004 | 05:38 AM
Burke's Avatar
Banned
Default Switching Exhaust housings on two turbos??
I have a t3/t4b .48 ar w/ a 5bolt and a t3/t04e .60 ar with a internally gated 4-bolt. both exhuast wheels are the same same size (.48) so i want to put the 5bolt on the to4e so i can use my existing downpipe, etc.
but i cant get them apart to do so. I cant hold get the nut off the end of the wheels cause i can hold the exhaust side still cause of that funky bolt pattern. where can i find a ratchet or wrench or something.
Thanks!!! You help is very much appreciated
Old Jan 3, 2004 | 02:36 PM
Burke's Avatar
Banned
Default Re: Switching Exhaust housings on two turbos?? (Burke)
bump
Old Jan 3, 2004 | 03:06 PM
Bailhatch's Avatar
You don't take the wheels off to change housings. just disconnect th Wg and the bolts that hold the turbine housing to the center section. Then carefully tap it appart. If you take the wheels off you will have to have the turobo rebalanced.
Old Jan 3, 2004 | 04:46 PM
ScottEK's Avatar
Default Re: Switching Exhaust housings on two turbos?? (Bailhatch)
So you can take the hot side off a turbo without disassembling the wheel? Anyone positive of this?
Old Jan 3, 2004 | 04:57 PM
RenoRacing's Avatar
Default Re: Switching Exhaust housings on two turbos?? (beta13)
Yes, you can take just the exhaust off.
Old Jan 3, 2004 | 05:06 PM
ScottEK's Avatar
Default Re: Switching Exhaust housings on two turbos?? (RenoRacing)
You have no clue how dissapointing that is to hear, I just put my turbo back on my car last night. It has been off for a couple weeks after I decided that it must be impossilbe to get the hot side off with the wheel assembled. I took out all the bolts that you loosen to clock the hot side. It still wouldn't come off?
I asked this same question and never got any responses:
https://honda-tech.com/zerothread?id=700250
Old Jan 3, 2004 | 08:33 PM
ScottEK's Avatar
Thanks...
Old Jan 3, 2004 | 10:03 PM
accordfreak's Avatar
man it's a PITA to take off the the exhaust housing.. i had smack mine off.. did you have to do the same?
Old Jan 4, 2004 | 07:56 AM
Bailhatch's Avatar
Default Re: Switching Exhaust housings on two turbos?? (accordfreak)
good jorb!
it would be cool to see pics of everyones messy benchs. I love seeing all the weird stuff everyone has on theirs. just a thought
Old Jan 4, 2004 | 08:05 AM
Burke's Avatar
Banned
update -
thanks for the help. i wacked the two housings off this morning. turns out the wheels are a little different so I cant switch them just gonna have to plug the internal gate.
THanks for all you help everyone!
Old Jan 4, 2004 | 08:08 AM
GraphiteAccord's Avatar
Burke, leave the gate how i had it adjusted, and you'll be alright to use a tial. It's adjuste to around 50lbs, and i don't think you'll go anywhere near that.
Old Jan 4, 2004 | 08:38 AM
Burke's Avatar
Banned
Default Re: Switching Exhaust housings on two turbos?? (GraphiteAccord)
will do. i was mainly trying to save some weight and to use my current downpipe. oh well.
thanks for the help
Burke
SPOOLINmatt
Dec 21, 2005 09:31 AM
O16581724 5 2 5
Nov 7, 2005 09:02 PM
jackhunt321
Sep 21, 2005 06:38 AM
TheIntegraGuy
Aug 9, 2005 11:00 AM
ELSpool
Nov 11, 2003 02:52 PM
