DA M/C works on EF's....
Old Jan 2, 2004 | 02:57 PM
sircrxracer's Avatar
Default DA M/C works on EF's....
Just to let you guys know, I had problems with my master cly or brake booster so I swaped it out with a 90 Integ non ABS one I didn't know if it would work but it bolts right up so glad cause it's a BITCH to get it out, it's alot bigger then the stock CRX one should be better I hope???. Btw it's a 90 CRX with rear disk. Rob
Old Jan 2, 2004 | 03:00 PM
crxgator's Avatar
Default Re: DA M/C works on EF's.... (sircrxracer)
did you use the booster too? yeah its 15/16 instead of the crx si 7/8...better pedal feel...i still need to upgrade mine...
Old Jan 2, 2004 | 03:03 PM
Default Re: DA M/C works on EF's.... (crxgator)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxgator &raquo;</TD></TR><TR><TD CLASS="quote">did you use the booster too? yeah its 15/16 instead of the crx si 7/8...better pedal feel...i still need to upgrade mine... </TD></TR></TABLE>
Yup it's the 15/16 and I used the booster too. Rob
FatalCrixer
Aug 16, 2008 12:18 PM
1_slow_crx
Apr 28, 2007 03:07 PM
Rob.
Jun 28, 2005 09:28 AM
WONG FRIED RICE
11
Nov 13, 2003 03:12 PM
CXHatchback
Jul 17, 2003 09:57 PM
