yummy parts came in today :)
Old Jan 2, 2004 | 01:47 PM
crxgator's Avatar
Default yummy parts came in today :)
well this arrived from holland and im sooo happy...
and my nice LHD rear foglight...i still have to hook it up the correct way, but for now this is cool...
before:
after:
*I am very, very, very sorry for the shitty *** pics...i am waiting on my tripod... *
i also have to hook it up the correct way, i just didnt have time today to mess around with some wiring...
anyone know a way i can wire it up to the reverse lights as well as a seperate switch?
Old Jan 2, 2004 | 02:09 PM
temp's Avatar
Default Re: yummy parts came in today :) (crxgator)
how did you hook up the foglight??!?!?!?! i am getting these so i need to know
Old Jan 2, 2004 | 02:12 PM
crxgator's Avatar
Default Re: yummy parts came in today :) (temp)
well right now, the foglight has the reverse lightbulb socket in it...but i took out the passenger side one, to show that one pic...what you need is the foglight switch and i guess hook it up with a power and a ground, it should work...i still need to work out the wiring for that unfortunatly...
Old Jan 2, 2004 | 02:28 PM
temp's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxgator &raquo;</TD></TR><TR><TD CLASS="quote">well right now, the foglight has the reverse lightbulb socket in it...but i took out the passenger side one, to show that one pic...what you need is the foglight switch and i guess hook it up with a power and a ground, it should work...i still need to work out the wiring for that unfortunatly...</TD></TR></TABLE>
oh i see, well i have a buddy in the netherlands that will send me the gauge hood from his VT which has the rear foglamp switch in place of the dimmer, and the entire wiring harness for the rear foglamp, i was just hoping it would be easier......
Old Jan 2, 2004 | 02:32 PM
crxgator's Avatar
if you have the harness you are in good shape...im going to have to rig something up, i have the switch with like a 3 inch of wiring and clip...
Old Jan 2, 2004 | 02:33 PM
temp's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxgator &raquo;</TD></TR><TR><TD CLASS="quote">if you have the harness you are in good shape...im going to have to rig something up, i have the switch with like a 3 inch of wiring and clip...</TD></TR></TABLE>
hmmmm do you think it might be at all possible to rig it into the OEM honda front foglamp switch? so that both the front and the rear come on w/ that switch?
EG8R's Avatar
Shouldn't be too hard. Just hook up a switched + wire to it. Thats if it is a constant ground.... Or vice versa.... Don't forget a fuse if you hook up a switched + wire....
Old Jan 2, 2004 | 02:34 PM
temp's Avatar
Default Re: yummy parts came in today :) (skelly ed6)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by skelly ed6 &raquo;</TD></TR><TR><TD CLASS="quote">Shouldn't be too hard. Just hook up a switched + wire to it. Thats if it is a constant ground.... Or vice versa.... Don't forget a fuse if you hook up a switched + wire....</TD></TR></TABLE>
i understand that but what i dont want is a ghetto rigged lookin switch, it must look stock or it must BE stock
Old Jan 2, 2004 | 02:38 PM
EG8R's Avatar
Well thats fine, use an OEM switch. The wiring is easy.
Old Jan 2, 2004 | 02:40 PM
crxgator's Avatar
yeah just splice an extra wire in the positive and ground wires of the front foglight switch...but if your getting the rear foglight switch, why not use that? thats what i have and am planning on doing and have my front fogs on its on oem foglight switch...
man i need to start putting all the wiring together for both front and rear so i can use them...
Old Jan 2, 2004 | 02:42 PM
EG8R's Avatar
Get on it man!!! What are you waiting for?!?!?!
Old Jan 2, 2004 | 02:44 PM
crxgator's Avatar
a miracle and warm weather...
Old Jan 2, 2004 | 02:45 PM
temp's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxgator &raquo;</TD></TR><TR><TD CLASS="quote">yeah just splice an extra wire in the positive and ground wires of the front foglight switch...but if your getting the rear foglight switch, why not use that? thats what i have and am planning on doing and have my front fogs on its on oem foglight switch...
man i need to start putting all the wiring together for both front and rear so i can use them... </TD></TR></TABLE>
because i dont know if i want to lose the dimmer, i dont know if i lose the dimmer if it will default it to the dimmest setting, etc
Old Jan 2, 2004 | 02:46 PM
crxgator's Avatar
you wont lose the dimmer...well the spot yes, but not the actual dimmer...i have the dimmer switch underneath and can be accessed by the way of the fuse panel...i leave it on full bright...
Old Jan 2, 2004 | 03:15 PM
bottlefedrex's Avatar
Hey Gator that looks real good, new toys are always great.
Old Jan 2, 2004 | 03:21 PM
TAG's Avatar
TAG
Default Re: yummy parts came in today :) (bottlefedrex)
Man!
I was looking for one of those rear tails w/ the foglight for a while, but I just gave up since I had so many other things to work on.
Nice to see you actually GOT one -- way to go man. Thanks for the pics
(oh yeah, please post better ones once you use your tripod, thanks)
Old Jan 2, 2004 | 05:29 PM
Simon Tibbett's Avatar
Looks great!
Old Jan 2, 2004 | 05:32 PM
crxgator's Avatar
Default Re: yummy parts came in today :) (TAG)
thanks for the kind words guys...TAG you should have looked at ebay a month or two ago, an aquantince was selling a set of EDM LHD tail light set, they only went for $120, this is for 90-91 center and left and right tail light...i missed out on it too ...i can see if i can get you one...although shipping is expensive...
Old Jan 2, 2004 | 08:31 PM
HatchBox's Avatar
Skoobie no more...
what exactly is the point of the rear foglight...sorry such a dumb question
Old Jan 2, 2004 | 09:08 PM
crxgator's Avatar
Default Re: yummy parts came in today :) (ind3ciso)
if its foggy out, i guess its so people wont rear-end you...
Old Jan 2, 2004 | 09:13 PM
HatchBox's Avatar
Skoobie no more...
cool. where do u find all these parts?
Old Jan 2, 2004 | 09:23 PM
crxgator's Avatar
all over the place, just got to search around on websites that arent from the us... hint ebay worldwide...
Old Jan 3, 2004 | 01:37 AM
SiR Kid's Avatar
New User
I've got a stocker fog light switch if you need one. $15, and I'll even cover the envelope and mail.
Old Jan 3, 2004 | 02:50 AM
crashtest Sonny's Avatar
Default Re: yummy parts came in today :) (SiR Kid)
hmm..interesting..so it takes up 1 reverse light spot.. so you'll only have 1 reverse light..?
learning something new everyday.
Old Jan 3, 2004 | 02:54 PM
temp's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by crxgator &raquo;</TD></TR><TR><TD CLASS="quote">you wont lose the dimmer...well the spot yes, but not the actual dimmer...i have the dimmer switch underneath and can be accessed by the way of the fuse panel...i leave it on full bright...</TD></TR></TABLE>
tight, when you remove the switch it stays at the last setting it was set at correct?
