89 Integra Rear Disc on Ej1
Old Jan 2, 2004 | 01:39 PM
sohcvtec1995's Avatar
Default 89 Integra Rear Disc on Ej1
I already posted in the Eg forum but maybe you guys know the answer. Will it fit? i looked at the rear and it is a straight bar going across. And my EJ1 is independent. What would I have to do if it dose work? Do i just pull the disk assemble out with out the control arms, and do the same with my car, and just swap out the parts? I really want to do it since the rear disc are Free to me. Also where is the Porpotioning valve on this car? and Can i use my e brake cable. Both cars are coupes.
Old Jan 2, 2004 | 04:52 PM
Default Re: 89 Integra Rear Disc on Ej1 (sohcvtec1995)
anyone?
Old Jan 2, 2004 | 07:29 PM
Hello. How are you? Great. Me, not good. Why you ask? oh no replys thats all. Bump For me.
Old Jan 2, 2004 | 07:32 PM
Echo7847's Avatar
I'm not too sure, but if I were you, I'd take them and sell them. Then find a set of 94-01 rear suspension like I did.
Old Jan 2, 2004 | 09:13 PM
Ninja Kitty
Guest
Posts: n/a
Default Re: 89 Integra Rear Disc on Ej1 (Echo7847)
that bar your refering to cannot be transplanted on to your car and the mounting hub size is wrong for a swap. Vtecvoodoo has the 11in fastbrakes kit f/s for 300
Old Jan 2, 2004 | 10:04 PM
Default Re: 89 Integra Rear Disc on Ej1 (Ninja Kitty)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ninja Kitty &raquo;</TD></TR><TR><TD CLASS="quote">that bar your refering to cannot be transplanted on to your car and the mounting hub size is wrong for a swap. Vtecvoodoo has the 11in fastbrakes kit f/s for 300</TD></TR></TABLE>
i am not going to transplant the whole rear bar. i just want the rear disc assembly. I was thinking about just taking all of the rear disc stuff (Rotor, Caliper,brake line,cable, porpotioning valve) and just taking off my rear drum assembly and kinda bolting it on there.
Old Jan 3, 2004 | 07:13 AM
TTT
Old Jan 3, 2004 | 08:15 AM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sohcvtec1995 &raquo;</TD></TR><TR><TD CLASS="quote">
i am not going to transplant the whole rear bar. i just want the rear disc assembly. I was thinking about just taking all of the rear disc stuff (Rotor, Caliper,brake line,cable, porpotioning valve) and just taking off my rear drum assembly and kinda bolting it on there.</TD></TR></TABLE>
I'm pretty sure that won't work. I've never heard of anybody just bolting on rear discs in place of drums, I think the trailing arms might be specific to each one of those.
Old Jan 3, 2004 | 05:51 PM
Echo7847's Avatar
Default Re: 89 Integra Rear Disc on Ej1 (PatrickGSR94)
You can unbolt it from the hub, there's a big nut on the back holding it all together. I believe this is what AEM's way of doing their 92-00 Ex rear disc conversion is. It has been done before in case you were wondering.
Old Jan 3, 2004 | 06:54 PM
Ninja Kitty
Guest
Posts: n/a
a 1g integra rear disk brake swap from a solid beam rear suspension to a 5g civic with rear indepndant suspension has been done before ?
Old Jan 4, 2004 | 04:08 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Echo7847 &raquo;</TD></TR><TR><TD CLASS="quote">You can unbolt it from the hub, there's a big nut on the back holding it all together. I believe this is what AEM's way of doing their 92-00 Ex rear disc conversion is. It has been done before in case you were wondering.</TD></TR></TABLE>
thanks i took the disc off the car today and dose look like it will work. When it gets done i will post a DIY on it. I knew there was some way of doing it. Thanks
*Boostwerks*
16
May 10, 2010 04:19 PM
Vcastro
Mar 30, 2007 10:11 AM
ED3_FTW
Dec 16, 2006 04:32 PM
DriftTheEg
Oct 7, 2005 05:45 AM
sohcvtec1995
Jan 3, 2004 10:39 AM
