car won't turn over
Old Jan 2, 2004 | 12:37 PM
lke2drvgsr's Avatar
Default car won't turn over
the battery is fine, except it's 1 of 3 problems... i have a fuel cutoff switch (maybe a wire somehow got loose or cut??) 2. fuel line somehow got cut or something? 3. no spark? anyway to check which it could be? anyone got ideas to help me out here??? thanks
'94 gsr
Old Jan 2, 2004 | 12:49 PM
lke2drvgsr's Avatar
Default Re: car won't turn over (lke2drvgsr)
is there anyway to check if i have spark or not? if i do, then atleast i know that im not flooding the engine... if i dont have spark, then damn... half my cylinders are filled with gas :-/
Old Jan 2, 2004 | 01:05 PM
someday's Avatar
im not an expert mechanic but i think if you pull out each plug wire off of the plug at a time and hold it to maybe another bolt on ur valve cover and have someone else crank it, if your ignition works then you shuld see the sparks, just dont hold with your hand use some pliers or something, and if you want to see if your getting fuel you could take off the fuel rail and see if it has gas in it, but first take off your intake and have a freind crank the car while you spray in some wd 40 if it starts then cool but wd 40 will start it. hope that helped
Old Jan 2, 2004 | 01:07 PM
2quik4rwd's Avatar
What computer are you using 14-8 or 14-9 if not sure look for the blue wire with yellow strip that is a 14-8. I over heard that this is a prob on the 14-8 comp it has to have 14 volts.
Old Jan 2, 2004 | 01:29 PM
lke2drvgsr's Avatar
Default Re: car won't turn over (2quik4rwd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2quik4rwd &raquo;</TD></TR><TR><TD CLASS="quote">What computer are you using 14-8 or 14-9 if not sure look for the blue wire with yellow strip that is a 14-8. I over heard that this is a prob on the 14-8 comp it has to have 14 volts.</TD></TR></TABLE>
um, huh?
Old Jan 2, 2004 | 01:31 PM
lke2drvgsr's Avatar
Default Re: car won't turn over (someday)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by someday &raquo;</TD></TR><TR><TD CLASS="quote">im not an expert mechanic but i think if you pull out each plug wire off of the plug at a time and hold it to maybe another bolt on ur valve cover and have someone else crank it, if your ignition works then you shuld see the sparks, just dont hold with your hand use some pliers or something, and if you want to see if your getting fuel you could take off the fuel rail and see if it has gas in it, but first take off your intake and have a freind crank the car while you spray in some wd 40 if it starts then cool but wd 40 will start it. hope that helped</TD></TR></TABLE>
ill try that plug thing, but how would spraying wd40 in the intake start the car..?
Old Jan 2, 2004 | 01:44 PM
2quik4rwd's Avatar
WD40 is not what you want it make things spin easier thats all. plus this is dangerous to do. you can get backfires. i told you which ecu do you have 14-8 or 14-9
Old Jan 2, 2004 | 01:48 PM
lke2drvgsr's Avatar
i have no idea what you're talking about, which ecu? i have a '94 gsr, obd1, mugen chipped ecu..
Old Jan 2, 2004 | 01:51 PM
xteg95's Avatar
yea to check for spark take a spark plug and put it next to something like your valve cover and it should spark, you sure its not the starter? is it clicking when you try and start it?
lke2drvgsr's Avatar
Default Re: car won't turn over (xteg01)
it sounds exactly like it should right before it turns over, but it just keeps doin that..
Old Jan 2, 2004 | 02:16 PM
tegforyou's Avatar
yea i heard that too about the 14-8. i was lucky . if your line was bad you would smell it if your plug is wet then you have fuel its that easy if you have no spark look into the ecu that 2quik4rwd was talking about.
Old Jan 2, 2004 | 02:25 PM
lke2drvgsr's Avatar
Default Re: car won't turn over (tegforyou)
lol can someone be nice enough to enlighten me as to what 14-8 means? and what all this talk about it is?
Old Jan 2, 2004 | 02:47 PM
tegforyou's Avatar
the 14-8 was the first style ecu that had a conducting problem with a int regulator that would not hold 14 volts to the ign module in the distributor. the 14-9 is the newer version.
Old Jan 2, 2004 | 02:49 PM
lke2drvgsr's Avatar
ok so what do i do about that blue wire? how would it go bad?
Old Jan 2, 2004 | 03:08 PM
tegforyou's Avatar
do you know now if its fuel or ign. if not sure still from wet plugs do you hear the pump come on when you turn the key to on position
Old Jan 2, 2004 | 04:57 PM
lke2drvgsr's Avatar
if i were to take off the fuel rail, what would i be looking at to see if fuel is going through? what's the procedure for this? thanks for the help
im still not sure if it's the fuel or there's no spark, im waiting for my dad to get home so he can help me check the spark.. if there is spark, then i hafta do the fuel rail thing
Old Jan 2, 2004 | 06:39 PM
lke2drvgsr's Avatar
ok well i'm getting a spark in the spark plugs, we're getting power across the fuel kill switch, and there's power being supplied to the fuel pump (we tested it all). but there's just no fuel going to the engine... does anyone know what it could be??? i need help! thanks
the fuel pump is turning on, we can hear it when we turn the key....
Modified by lke2drvgsr at 10:52 PM 1/2/2004
Old Jan 2, 2004 | 08:49 PM
lke2drvgsr's Avatar
can anyone show me a diagram of where the fuel lines run, from the fuel pump, into the injectors, the full process they go through? id greatly appreciate it, i want to take off one hose and try starting the car.. see if anything comes out... the fuel pump IS turning on, but maybe it's broken and not pumping fuel anymore?
Old Jan 2, 2004 | 08:56 PM
Ninja Kitty
Guest
Posts: n/a
make sure the harness clips are tight sometimes they can get loose.
Old Jan 2, 2004 | 08:58 PM
lke2drvgsr's Avatar
Default Re: car won't turn over (Ninja Kitty)
if there's power being supplied to the fuel pump and the fuel pump is turning on, i don't really see how it can be an electrical problem..?
Old Jan 2, 2004 | 11:02 PM
lke2drvgsr's Avatar
update: on me, i forgot i had a fuel pressure gauge lol anyway, i have 45 psi of fuel, what the ****... i have fuel pressure in the lines.. i have spark... WHY DOESN'T **** GO BOOM?!
Old Jan 3, 2004 | 01:43 AM
deepgreengsr's Avatar
did this start after sitting one day? or were you ******* around with it and changes something?
Old Jan 3, 2004 | 05:49 AM
OC 335i's Avatar
How many miles are on your car?
Have you checked your distributor rotor?
Old Jan 3, 2004 | 08:49 AM
lke2drvgsr's Avatar
Default Re: car won't turn over (JMS JT)
i havent touched a thing, 2 days later it didn't start..
i havent been having any problems with it at all, and suddenly it just decides not to start, everything was working fine..
Old Jan 3, 2004 | 08:59 AM
OC 335i's Avatar
If it's not turning over, the distributor rotor is a common failure.
Most common failures for Hondas that do not start are the distributor rotor, bad ignitor, and battery. Usually when you do maintenance on it, you change the distributor cap and rotor.
Again, how many miles are on your motor?
