arp rod bolts install
Old Jan 2, 2004 | 12:01 PM
sikcrx80's Avatar
Default arp rod bolts install HELP!!!
i am taking apart my engine and replacing my rod bolds with some arp rod bolts.
arp says something about torqing them to 26 and in the honda book it say 30.
i thought it should be aleast factor specs...
What if i torqe them to factory specs?
Modified by sikcrx80 at 10:49 PM 1/4/2004
Old Jan 2, 2004 | 12:22 PM
Mikey3000's Avatar
Default Re: arp rod bolts install (sikcrx80)
go with ARP's specs. they are ARP's bolts not Honda's. go with the manufacturer's specs with all aftermarket parts not Honda's.
Old Jan 2, 2004 | 12:46 PM
irev210's Avatar
Default Re: arp rod bolts install (Mikey3000)
be sure to take it to a machine shop and check the rod, as the arp's can often cause the rod to egg shape because of the increased clamping pressure
Old Jan 2, 2004 | 01:51 PM
sikcrx80's Avatar
but arp calls for less torqe then factory 30
so how can it wreck anything?
has anybody else done this?
Old Jan 2, 2004 | 02:07 PM
K20EG's Avatar
Default Re: arp rod bolts install (irev210)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by irev210 &raquo;</TD></TR><TR><TD CLASS="quote">be sure to take it to a machine shop and check the rod, as the arp's can often cause the rod to egg shape because of the increased clamping pressure</TD></TR></TABLE>
Good Advice
Also be sure to torque and untorq the rods bolts 3-4 times
Old Jan 2, 2004 | 04:40 PM
chad's Avatar
Moderator
DO IT BY ARP!! you do not have HONDA RODS...you have ARP rods....
Old Jan 2, 2004 | 04:46 PM
K20EG's Avatar
Default Re: arp rod bolts install (chad)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chad &raquo;</TD></TR><TR><TD CLASS="quote">DO IT BY ARP!! you do not have HONDA RODS...you have ARP rods....</TD></TR></TABLE>
yes torque them to 26 4 times over
you will be fine
i recomend having the rod checked as well
Old Jan 3, 2004 | 07:06 AM
klnteg's Avatar
Just finger tighten them brett, they should be go to go then!!!
Old Jan 4, 2004 | 10:45 AM
sikcrx80's Avatar
but when i say arp says to torqe them to 26 it is really the stretch process.. or is it?
Old Jan 4, 2004 | 11:07 AM
rudebwoy's Avatar
Default Re: arp rod bolts install (K20EG)
why do you need to torque and untorque 4 times?<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by K20EG &raquo;</TD></TR><TR><TD CLASS="quote">
Good Advice
Also be sure to torque and untorq the rods bolts 3-4 times </TD></TR></TABLE>
Old Jan 4, 2004 | 11:10 AM
sikcrx80's Avatar
to streatch them...
Old Jan 4, 2004 | 11:17 AM
rudebwoy's Avatar
Default Re: (sikcrx80)
I thought ARP bolt dont stretch, that easiliy.
Old Jan 4, 2004 | 11:20 AM
sikcrx80's Avatar
anyone!!!!
Old Jan 4, 2004 | 11:34 AM
VtecDA9's Avatar
"out of round" correct. then balance your bottom end rotating asembly for good measures
Old Jan 4, 2004 | 11:44 AM
sikcrx80's Avatar
well i just wanted to just replace factory rod bolts and this is sounding like alot more work for just changing rod bolts...
i dont know what to do now
Old Jan 4, 2004 | 01:48 PM
sikcrx80's Avatar
what would happen if i just put ARP rod bolts in and torqed them to factory specs.
how could that make rods egg shaped?
Old Jan 4, 2004 | 02:47 PM
K20EG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sikcrx80 &raquo;</TD></TR><TR><TD CLASS="quote">what would happen if i just put ARP rod bolts in and torqed them to factory specs.
Torque them to 26 4 times ...put the whole factory spec thing outta your mind its wrong.
I have done them before without checking the rods and you definetly dont need to balace the bottom end for this
Good luck
Old Jan 4, 2004 | 05:43 PM
sikcrx80's Avatar
so u think torqe them to 26 4 times and leave them at 26.
Old Jan 5, 2004 | 12:58 AM
K20EG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sikcrx80 &raquo;</TD></TR><TR><TD CLASS="quote">so u think torqe them to 26 4 times and leave them at 26.
Yep
Old Jan 5, 2004 | 08:28 AM
owen_the_soyboy's Avatar
Default Re: (K20EG)
Yep</TD></TR></TABLE>
Old Jan 5, 2004 | 01:52 PM
sikcrx80's Avatar
so do ya think if i torqe them to 26 it will make my rod egg shaped?
Old Jan 5, 2004 | 02:00 PM
K20EG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sikcrx80 &raquo;</TD></TR><TR><TD CLASS="quote">so do ya think if i torqe them to 26 it will make my rod egg shaped?</TD></TR></TABLE>
My physic powers are in coma right now ill have to get back with you
Old Jan 5, 2004 | 02:09 PM
sikcrx80's Avatar
come on man.. just looking for anyone thats did it with out getting them checked.
i dont really want to pull them out but if i have to... oh well
Old Jan 5, 2004 | 02:13 PM
K20EG's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sikcrx80 &raquo;</TD></TR><TR><TD CLASS="quote">come on man.. just looking for anyone thats did it with out getting them checked.
i dont really want to pull them out but if i have to... oh well</TD></TR></TABLE>
I did 3 or 4 like that without getting check over a year ago cars still running strong today
Old Jan 5, 2004 | 07:22 PM
sikcrx80's Avatar
well thats good to know.. i call my local shop and they want 10 to check rod and 22 to fix tem if needed to.. i just really dont want to take them out..
