why?????
Old Jan 1, 2004 | 09:35 PM
1point5CRX's Avatar
Default why?????
i installed a set of reverse indiglo guages for my 91 crx.now the tach and speedo dont move,gas and temp work fine.actually the speedo will get up to 30-40mph when im on the highway probably going 70-80
ThatRicerDaniel's Avatar
Default Re: why????? (1point5CRX)
why would you install that?
Old Jan 1, 2004 | 09:36 PM
crxgator's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1point5CRX &raquo;</TD></TR><TR><TD CLASS="quote">i installed a set of reverse indiglo guages for my 91 crx.now the tach and speedo dont move,gas and temp work fine.actually the speedo will get up to 30-40mph when im on the highway probably going 70-80 </TD></TR></TABLE>
ricers make baby jesus cry...
you probably moved the needles when you took them off and fucked it up...
Old Jan 1, 2004 | 09:37 PM
JonGP4's Avatar
you proably tighten the screws that hold the gauges on.. to tight.
you caused the little wire in the back to break off.. so in otherwords you fucked it up.. find a new gauge and ditch the indiglo's
Old Jan 1, 2004 | 09:45 PM
1point5CRX's Avatar
Default Re: why????? (JonGP4)
the guages are overlays,theres nothing to **** up.the needles werent touched and the plugs in the back are all connected
Old Jan 1, 2004 | 09:56 PM
JonGP4's Avatar
you had to take out those screws in the front tho right?.. if so when you put them back on you tighten them to tight.. thats what it is.. 99% sure man
Old Jan 1, 2004 | 09:59 PM
crxgator's Avatar
how do you put on gauges without removing needles?
Old Jan 1, 2004 | 10:02 PM
phatrick2332's Avatar
slide the needle through the hole in the center of the guage overlay.
Old Jan 1, 2004 | 10:03 PM
crxgator's Avatar
Default Re: (phatrick2332)
the needles would still be moved or touched even if you did try that...
and you would have to remove the screws to hold on the overlay, and such...
ilovemyd16
Sep 21, 2007 11:44 AM
flashedDc5
17
Sep 28, 2006 07:13 PM
Ragged91ZC
Sep 18, 2005 10:59 PM
tasco
Jul 13, 2005 03:10 PM
