b20 power????
Old Jan 1, 2004 | 12:02 PM
cliff666's Avatar
Default b20 power????
i am lookin into replacing my shot b18b wit a b20. now i am only considering the b20 with the higher comp because i hear they are better for vtec anyways(thinkin later on vtec head w/stock bottom maybe). but anyways back to my question my previous b18b setup only made a shitty 122@whp w/112 torque and now with a b20b (JDM) will i be sure making more power than that????? all i had on the b18b was a cheap cold air intake and a exhaust. what killed me all the time was lack of top end. now with a 4-1 header maybe and a skunk2 IM would that help where the b18b left off??????
i ran a 14.8@92 consistantly with 2.1 60's and best of 14.7@94. i want to aim for about mid low 14s all motor on the b20 no vtec first. w/o the use of upgraded internals. what else would be needed to get to this goal? and also what b20b the years should i be looking for i kno i need to look for the ones with the factory knock sensor because the lower compression ones didnt have them. but what else should i be looking for the guy i talked to abuot buying a block said 97 up there where high compression b20b's but then i read from a thread here that 99+ up JDM b20b's had the higher compression not the 97s. just lookin for more insight someone help me lol.
thanks in advance
Old Jan 1, 2004 | 02:13 PM
8200RPM's Avatar
local hippie
Default Re: b20 power???? (dragboy)
correct me if im wrong but I believe the b20b has a cr of 8.8:1 and the b20z has a cr of 9.6:1
read this...
http://www.theoldone.com/articles/badtothebone/
Modified by 8200RPM at 3:45 PM 1/1/2004
Old Jan 1, 2004 | 02:16 PM
Dancing is Forbidden's Avatar
Default Re: b20 power???? (8200RPM)
if you want to run low 14's high 13's with a b20, get a JDM ITR tranny. I run that with a b18b and a jdm itr tranny.
Old Jan 1, 2004 | 05:16 PM
puqua's Avatar
The 99-00 jdm b20b have the higher comp. Pull the head if possible, and check the pistons. They should be phk pistons.
Why not just get a usdm b20z?
Old Jan 1, 2004 | 07:04 PM
cliff666's Avatar
Default Re: b20 power???? (paty boy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by paty boy &raquo;</TD></TR><TR><TD CLASS="quote">The 99-00 jdm b20b have the higher comp. Pull the head if possible, and check the pistons. They should be phk pistons.
Why not just get a usdm b20z?</TD></TR></TABLE>
cause i looked in nj and everyone was tryin to dick me on price. if u kno someone wit a b20z since u live in nj gimme a shout i got loot on me right now i just need my car to run.
Happyfeat2006
Mar 6, 2009 02:21 PM
tpb18b1
Jul 4, 2005 12:59 PM
redsled00
Apr 10, 2003 10:09 PM
ActiveAero
Feb 9, 2003 09:39 AM
