CRVtec crankcase pressure prob
Old Jan 1, 2004 | 09:07 AM
H2nr's Avatar
Default CRVtec crankcase pressure prob
How have you guys solved the crankcase pressure problem with the CRVtec. The B20 runs the PCV into the valve cover, and there is no oil evap can on the back of those blocks. When you put a Vtec head on that block then where do you install the PCV?
Old Jan 1, 2004 | 09:40 AM
Dancing is Forbidden's Avatar
Default Re: CRVtec crankcase pressure prob (H2nr)
you run a catch can...
Old Jan 1, 2004 | 11:43 AM
H2nr's Avatar
Default Re: CRVtec crankcase pressure prob (EF9_SiR)
can you explane more............ like where in the block or head are you jumping in for the lines for the can?
Old Jan 1, 2004 | 12:55 PM
chris@allmotor.net's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by H2nr &raquo;</TD></TR><TR><TD CLASS="quote">can you explane more............ like where in the block or head are you jumping in for the lines for the can? </TD></TR></TABLE>
http://theoldone.com/components/breather/
Old Jan 1, 2004 | 02:12 PM
allmotorgsrekk's Avatar
Default Re: CRVtec crankcase pressure prob (chris@allmotor.net)
Endyn catchcan
Old Jan 1, 2004 | 02:14 PM
Default Re: CRVtec crankcase pressure prob (allmotorgsrekk)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by allmotorgsrekk &raquo;</TD></TR><TR><TD CLASS="quote">Endyn catchcan </TD></TR></TABLE>****, I got a Coffee can.
milkmanLCA
Oct 5, 2008 07:55 PM
90hatchb16
50
Aug 25, 2006 07:04 PM
walkerklondyke2000
Jan 12, 2006 10:11 PM
Darkane
Sep 4, 2004 04:26 PM
maximumground
10
Mar 1, 2004 08:32 PM
