Fuel system/ injector cleaner at every oil change?
Old Sep 25, 2001 | 04:00 PM
Mike95lude's Avatar
Default Fuel system/ injector cleaner at every oil change?
I'm changing my oil sometime in the next couple days and personally haven't ever dumped in any fuel injector cleaner or anything in since I've had my Lude.
What do you do/recommend for your vehicle?
Old Sep 25, 2001 | 07:42 PM
JKPRELUDE's Avatar
Default Re: Fuel system/ injector cleaner at every oil change? (Mike95lude)
Well if you're gonna put that stuff in, I would suggest some STP fuel system cleaner. If you buy the expensive stuff you're just paying for the name. Go with the STP stuff. Its cheap and it does all the same stuff as all the others.
Old Sep 26, 2001 | 10:07 AM
Mike95lude's Avatar
Default Re: Fuel system/ injector cleaner at every oil change? (JKPRELUDE)
anyone alse got any input? I want to buy this stuff after work in less than 30 min
Old Sep 26, 2001 | 10:20 AM
GraphiteAccord's Avatar
unless you are having fueling problems, i wouldn't recommend it. Change your fuel filter, and have your injectors flow tested instead of putting that stuff in your tank.
Old Sep 26, 2001 | 10:27 AM
Mike95lude's Avatar
Default Re: Fuel system/ injector cleaner at every oil change? (GraphiteAccord)
Good idea, thanks
Old Sep 26, 2001 | 03:30 PM
Mike95lude's Avatar
I bought some Gumout Regane after further research. Going to put that in with my next tank of gas. Everyone seems to accept this stuff as good.
BKJJ77
Mar 5, 2012 08:41 AM
SlowEJ8
27
Apr 19, 2009 07:57 PM
Turbo95Hatch
Oct 2, 2006 10:25 PM
neodre
Aug 16, 2006 12:43 PM
vtecdc2
Aug 5, 2002 10:56 PM
