help taking out abs and making my 94 teg non abs
Well I decided to remove my abs brake system, but Would I just use an RS setup to make it non abs or is there an easier way thanks for all the help
_______
_______
unless your really hardcore racer i wouldnt bother.
i did it becuase my car is hardcore and needs the weight gone.
basically just take out the abs unit, and all the lines for the front brakes. I then took off the ABS prop valve and replaced it with a 2nd gen Teg prop valve and then went to Advanced auto and got new hardlines for the front and bent thme to how i wanted them . ill see if i can find some pics of how we did mine.
actually if you search, youll see pics of mine from a few months ago, try that
thank you very much man My car is going to be hard core it just isn't right now but since the motor is out I decided to paint the engine bay and thought this would be an easy time to convert it, thanks though man
any parts store carries them , they are like $2.50-3.00 a piece maybe. . i forget what sizes i ended up going with off hand though. but like i said if you search around you can see pics of my install, it looks hella nice.
GeorgeJetson
May 15, 2004 09:02 PM
