Anyone use the stock bolts w/ the Benen Lower Tie Bar?
Old Dec 31, 2003 | 05:08 PM
civicdohc's Avatar
Default Anyone use the stock bolts w/ the Benen Lower Tie Bar?
i got a Benen Lower Tie Bar but no bolts so i was wondering if anyone used the stock ones. I put it one but the bolts dont go all the way through. Is it safe?
thanks
Old Dec 31, 2003 | 05:15 PM
Noe Kozz's Avatar
Default Re: Anyone use the stock bolts w/ the Benen Lower Tie Bar? (civicdohc)
just get a longer bolt at your local auto part store, I have a skunk2 lower tie bar and the bolt is longer than stock, I was gonna change it for a spoon lower tie I have here in my room but didn't feel like finding another stock bolt, so I just left it on. It's for sale by the way (spoon lower tie bar)
Old Dec 31, 2003 | 06:52 PM
whoDAT's Avatar
Default Re: Anyone use the stock bolts w/ the Benen Lower Tie Bar? (Noe Kozz)
i'm using stock bolts with my benen lower tie bar and have no porblems with it what so ever. i believe they come equipped with extra bolts (which are longer but not self guiding) is to accomadate for the spacers when you are using an itr sway bar + beaks/bsq kit. also to answer you question, it is definately not safe if it isn't going through all the way. go out and find another bolt that's longer with the same thread pitch. also, make sure it is grade 8...automotive strength.
Modified by whoDAT at 4:03 AM 1/1/2004
Old Dec 31, 2003 | 06:55 PM
kommon_sense's Avatar
Default Re: Anyone use the stock bolts w/ the Benen Lower Tie Bar? (whoDAT)
my benen rear lower tie bar came with longer bolts.
Teh Boss
Dec 22, 2012 08:29 PM
CRX EF 88
12
Feb 20, 2008 05:54 AM
AllSpedup04
Sep 27, 2005 12:24 PM
AzntstyleZ
Jan 26, 2004 12:05 PM
