What modifications are needed to run DSM 450cc injectors in a 96 Civic?
Old Dec 31, 2003 | 12:43 PM
Altered's Avatar
Default What modifications are needed to run DSM 450cc injectors in a 96 Civic?
I know the DSM 450cc injectors are peak and hold and all 92+ civics are saturate but is there anything you can do to convert fron saturate to peak and hold?
If so can you please list what mods/changes are necessary to do so?
Old Dec 31, 2003 | 12:58 PM
bigwig's Avatar
injector clips and resistors
Old Dec 31, 2003 | 01:08 PM
Altered's Avatar
Default Re: (bigwig)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by bigwig &raquo;</TD></TR><TR><TD CLASS="quote">injector clips and resistors</TD></TR></TABLE>
When you say resistors are you refering to the resister box? If so, cant a resistor box from another peak and hold vehicle such as a 88-91 CRX be used instead?
Old Dec 31, 2003 | 01:09 PM
p0gi's Avatar
Default Re: (Altered)
yes or you can get 10watt 10 ohm resistors from radio shack
Old Dec 31, 2003 | 01:21 PM
Altered's Avatar
Default Re: (p0gi)
ok, cool. So heres the run down of whats needed,
1. DSM 450cc injectors w/ clips
2. 88-91 Civic/92-95 Prelude Injector Resistor Box
Can you still run the 96 EX ECU with out any problems? Or will that need to changed as well?
Old Dec 31, 2003 | 01:35 PM
rudebwoy's Avatar
Default Re: (p0gi)
screw radio shack! just go to the junk yard and get a resister box from a 89-91 prelude/accord/ civic, much cleaner setup, easier to hookup. its that aluminum box in the fire wall of a older civic,or on the wheel well of a older prelude or accord, worked perfectly, and at least you know they are made by honda, they are also on ebay, if you are layzy and dont want to go get it yourself I can can get you one $20 shipped.
Old Dec 31, 2003 | 01:50 PM
Altered's Avatar
Default Re: (rudebwoy)
I have several of them, I do B16 swaps for friends and neighborhood racers some of whom have 88-91 DX's and need them for the 2-4 injector conversion. I try to have at least one around. I have a yard about a mile from me full of them.
Old Dec 31, 2003 | 02:15 PM
rudebwoy's Avatar
cool! you can start sale of them on egay
Old Dec 31, 2003 | 04:26 PM
scttydb411's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Altered &raquo;</TD></TR><TR><TD CLASS="quote">ok, cool. So heres the run down of whats needed,
Can you still run the 96 EX ECU with out any problems? Or will that need to changed as well?</TD></TR></TABLE>
yes...just make sure you have the resistorbox and wired correctly and the stock ecu will be ok...oh yeah, and a afc/smc too.
cb169
Oct 10, 2007 09:09 PM
mortificationrock
Jun 10, 2007 09:05 PM
b17a1crx
Sep 10, 2006 07:27 PM
Happyman
Jul 7, 2003 06:37 AM
sivik2nr
Jun 11, 2003 09:59 PM
