Clutch Question (First time replacing clutch on my own)
Old Dec 31, 2003 | 06:54 AM
VASlowTec's Avatar
Default Clutch Question (First time replacing clutch on my own)
I need to know how many foot pounds of torque to put on the pressure plate on a stock 88 crx si d16a6 and how important is it to have the flywheel resurfaced and also how much torque on those bolts
Old Dec 31, 2003 | 07:06 AM
Jet Black's Avatar
Default Re: Clutch Question (VASlowTec)
Flywheel resurfacing isnt necessary unless the flywheel is scored or damaged, but its allways a good idea.
I believe the flywheel bolts are something like 45 ft-lbs and the pressure plate bolts are 18 ft-lbs.
But those are just from memeory, look it up in a shop manual online
http://tech.hybridgarage.com
MAKE SURE TO USE A 12 sided socket on those bolts
Old Dec 31, 2003 | 07:11 AM
VASlowTec's Avatar
Default Re: Clutch Question (Jet Black)
ok thanks
Old Dec 31, 2003 | 07:25 AM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
From the 1988 manual
flywheel=87 lb-ft
clutch cover/pressure plate=19 lbs-ft
Do surface the flywheel while you have it out..
that way you won't have any regrets...
Old Dec 31, 2003 | 07:27 AM
Jet Black's Avatar
Default Re: Clutch Question (88DXCRX)
Yikes! I was wayy off...makes sense tho, I rememebr struggling to torque em.
Acidcrakker
Jul 3, 2012 05:35 AM
danthemang3
Jun 20, 2009 11:37 PM
project-boosteD
Nov 30, 2004 09:41 PM
CivicEx95
Apr 24, 2002 10:50 PM
