Emmissions question - NOx level too high
Old Dec 31, 2003 | 06:53 AM
vtec.dc2's Avatar
Default Emmissions question - NOx level too high
This is on obd1 DX, all stock but failed with NOx. The car fuel economy isn't so great, but paper suggest it might be running lean, air intake temps too high, bad oxygen sensor and few otheres. there are no cooling issues with the car. I was thinking to replace ignition components, like spark plugs or will that make things worse?
Old Dec 31, 2003 | 08:15 AM
the jdmchop's Avatar
Default Re: Emmissions question - NOx level too high (vtec.dc2)
you must have a check engine light on?if so check it
replace whats bad like u said the o2, some fresh plugs and if all fail retard that bitch, in turn should lower the temps and create lower NOx to much NOx is caused by exhaust temps reaching over 2,500 degrees!
Old Dec 31, 2003 | 08:36 AM
vtec.dc2's Avatar
Default Re: Emmissions question - NOx level too high (jdmchop)
there are no cel's.. i'm gonna replace sparks, maybe rotor, check timing and pull it back to maybe 14. any other ideas?
Old Dec 31, 2003 | 08:39 AM
esoterEK..'s Avatar
see if this helps https://honda-tech.com/zerothread?id=313708
Old Dec 31, 2003 | 08:45 AM
vtec.dc2's Avatar
Default Re: Emmissions question - NOx level too high (EGkwazhimoto)
thanks, it has a post regarding NOx.
skymanAR
10
Jun 7, 2013 12:14 AM
mikeycivic
Mar 8, 2010 06:59 PM
platinum00
Engine Management and Tuning
Aug 1, 2009 11:21 AM
Civic_07
Jun 10, 2008 04:49 PM
thatbluecrx
Sep 23, 2004 03:41 PM
