The sputter
Old Dec 31, 2003 | 06:50 AM
infinatenexus's Avatar
Default The sputter
Recently I just built another motor for my Civic. I used a Y7 block, and Y8 head. The engine management is a HondataS-100, and I am running a Comp cams 59300. I have a MSD 6AL ignition, with a Blaster 2 coil.
It runs great with the exception of one problem. Once I go into VTEC (5300 RPM's), it sputters, and miss fires. With the exception of the distributer, I have replaces/re wired every electrical component in an attempt to eliminate this problem.
Any suggestions,, or should I bite the bullet and get a new distributer?
Modified by infinatenexus at 9:52 AM 12/31/2003
Old Dec 31, 2003 | 08:53 AM
Default Re: The sputter (infinatenexus)
I just swapped in a PM6 ECU (non VTEC). It dose the same thing at 5300 RPM's.
Old Dec 31, 2003 | 04:39 PM
Guess nobody knows?
Old Dec 31, 2003 | 06:32 PM
dsadas89das78934's Avatar
bump for a friend.
Old Dec 31, 2003 | 06:43 PM
Default Re: (soccaian)
Looks liek I am ordering a new dizzy
Old Dec 31, 2003 | 06:50 PM
Default Re: (infinatenexus)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by infinatenexus &raquo;</TD></TR><TR><TD CLASS="quote">Looks liek I am ordering a new dizzy </TD></TR></TABLE>
i thought you were goin to bed fool...
Old Dec 31, 2003 | 06:55 PM
sohcvtec66
Guest
Posts: n/a
change your spark plugs and plug wires.. maybe change your cap and rotor.and last of all fuel pump, and main relay, and grounds wires
Old Dec 31, 2003 | 06:59 PM
Ass_Clown's Avatar
Default Re: The sputter (sohcvtec66)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sohcvtec66 &raquo;</TD></TR><TR><TD CLASS="quote">change your spark plugs and plug wires.. maybe change your cap and rotor.and last of all fuel pump, and main relay, and grounds wires</TD></TR></TABLE>
BTW nice avatar!! ***** are nice.
Old Dec 31, 2003 | 11:53 PM
his plugs, wires, cap and rotor are all new...
Old Jan 1, 2004 | 03:41 AM
Jimmy's Avatar
Global Moderator
i'd say new dizzy
Old Jan 1, 2004 | 05:55 AM
Default Re: (USDMDC2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by USDMDC2 &raquo;</TD></TR><TR><TD CLASS="quote">i'd say new dizzy </TD></TR></TABLE>
Yup.... thas what I am thinking.
LSTEG96
Oct 14, 2007 11:25 PM
Dartanian
Mar 26, 2006 06:48 PM
88cerx
Feb 23, 2005 03:39 PM
typeeg
Honda Motorcycles
Sep 30, 2004 02:43 PM
PolishRacing1
Sep 14, 2004 11:37 AM
