Brake upgrades?
Old Dec 30, 2003 | 10:46 PM
revhigh96's Avatar
Default Brake upgrades?
I was just thinking about what upgrades I am going to do to my braking system. SS lines are a must. I was originally thinking of a big brake kit because my 17" rims will easily clear but I really would like to be able to put down to 14" back on my car for track days. What do you guys think will be a good solution for my brakes?
completely stock brakes on a 96 EX
B18C5 Turbo under the hood (thats why I really need brakes soon)
Thanks
Old Dec 30, 2003 | 11:06 PM
MaxSterling's Avatar
Default Re: Brake upgrades? (revhigh96)
only solution is better pads, can't do much with 14" wheels
Old Dec 30, 2003 | 11:07 PM
=GAME='s Avatar
Default Re: Brake upgrades? (MaxSterling)
gsr front and rears with good rotors and pads.
this would be more then enough.
Old Dec 30, 2003 | 11:14 PM
Default Re: Brake upgrades? (O.G triple O.G)
he has civic ex brakes, which are the same as gsr
Old Dec 30, 2003 | 11:15 PM
=GAME='s Avatar
same diameter, smaller calipers.
Old Dec 30, 2003 | 11:21 PM
xJ.SLOTHx's Avatar
why not go 15's for the track?
Old Dec 31, 2003 | 12:59 AM
ramz7887's Avatar
Default Re: Brake upgrades? (ian)
what about wilwood brakes. Or if you have a lot of money brembo. But both these setups maybe too much for what you need.
Old Dec 31, 2003 | 02:02 AM
Evs-One's Avatar
Solbros Owns Me
ITR brakes with 4 lug 14 inch CE28N's
Old Dec 31, 2003 | 02:31 PM
revhigh96's Avatar
how hard is it to put GSR calipers on my car? also are there any good performace rotors that are out there?
Old Dec 31, 2003 | 11:14 PM
revhigh96's Avatar
I allready tried searching but what else do I need besides the GSR caliper itself for it to bolt right up? Also what have your experiences been with aftermarket rotors, inparticular slotted but not cross drilled?
Old Dec 31, 2003 | 11:21 PM
D50boy's Avatar
Default Re: Brake upgrades? (Emerika)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Emerika &raquo;</TD></TR><TR><TD CLASS="quote">ITR brakes with 4 lug 14 inch CE28N's
Fawk that's a tight fit! Looks killer!
About how much do those wheels go for?
Old Dec 31, 2003 | 11:59 PM
p0rnstar's Avatar
Pads and SS lines should do the trick...the stock systems are designed to withstand more than stock power anyways to pass certain cerifications..
I recommend Hawk pads.
Old Jan 1, 2004 | 12:00 AM
Evs-One's Avatar
Solbros Owns Me
Default Re: Brake upgrades? (D50boy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by D50boy &raquo;</TD></TR><TR><TD CLASS="quote">
About how much do those wheels go for?</TD></TR></TABLE>
I think 1100 or so
Old Jan 1, 2004 | 12:02 AM
egizzle8
Guest
Posts: n/a
</TD></TR></TABLE>**** that is a pretty tight fit. Did you have to machine any of the rotor or run some spacers? Looks good though. Just need some tires now!
Old Jan 1, 2004 | 12:32 AM
Targa250R's Avatar
be professional
Default Re: (revhigh96)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by revhigh96 &raquo;</TD></TR><TR><TD CLASS="quote">how hard is it to put GSR calipers on my car? also are there any good performace rotors that are out there?</TD></TR></TABLE>
Rotors do not have "performance." Rotors are only there as a heat sink; they are a wear item. Spending extra money for fancy drilled and/or slotted rotors over the cheaper blanks is just a waste because there are no real benefits. Not to mention, modified rotors tend to form stress cracks more quickly.
If you want to upgrade your stopping power and avoid fade, then upgrade tires first, then pads and fluid.
First of all, what do you do with the car? And what are the limitations of your current brake system?
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MaxSterling &raquo;</TD></TR><TR><TD CLASS="quote">can't do much with 14" wheels</TD></TR></TABLE>
Yeah unless they're 14x7s or wider. IMHO 13s are much better. Too bad the only 13x8s that fit over 10.3" front brakes are pricey Panasports.
Old Jan 1, 2004 | 12:38 AM
Evs-One's Avatar
Solbros Owns Me
Default Re: (Targa250R)
Of course some rotors are going to perform better than others....hence the "performance"
Most road racers prefer off the shelf blanks, such as myself, because they are cheap and do the trick.
But, you can get ceramic treated rotors which displace heat a lot better, etc.
Old Jan 1, 2004 | 12:44 AM
Targa250R's Avatar
be professional
Default Re: (Emerika)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Emerika &raquo;</TD></TR><TR><TD CLASS="quote">Of course some rotors are going to perform better than others....hence the "performance"
But, you can get ceramic treated rotors which displace heat a lot better, etc.</TD></TR></TABLE>
Ceramic? I think you mean cryogenically treated rotors.
And these do nothing to improve stopping power or heat dissipation - cryogenically treated rotors simply last longer and aren't worn away by the pads as easily.
Like I said - the rotor is just a heat sink and is a wear item, don't bother with fancy rotors.
Old Jan 1, 2004 | 01:07 PM
revhigh96's Avatar
I am going to auto x and track my car so stoping power is a must. Just messing around on the streets gives me terible brake fad. I also dont mind spending a bit of money to get something that will really work. I have honda OEM rotors and now they get really hot. I do agree with whats posted above that cross drilled rotors will eventually crack from repeated track use (not drag I mean race track) I have seen it happen.
Are GSR calipers worth the upgrade over the stock EX ones?
As far as pads what have you guys like and disliked?
Also what fluid is good? I have never really looked into changing it but it seems like it could have a huge imact.
Old Jan 1, 2004 | 01:58 PM
SuicideSlide's Avatar
bump
Old Jan 1, 2004 | 06:24 PM
locass316's Avatar
if you gotta stay with the 14s then I say upgrade to the gsr calipers with some bad *** pads and fluid. but if I ever made that much power, Id really look at a better brake setup to match that power
Old Jan 1, 2004 | 08:57 PM
kommon_sense's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by revhigh96 &raquo;</TD></TR><TR><TD CLASS="quote">I am going to auto x and track my car so stoping power is a must. Just messing around on the streets gives me terible brake fad. I also dont mind spending a bit of money to get something that will really work. I have honda OEM rotors and now they get really hot. I do agree with whats posted above that cross drilled rotors will eventually crack from repeated track use (not drag I mean race track) I have seen it happen.
IMHO, no.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote &raquo;</TD></TR><TR><TD CLASS="quote">
AEM pads have worked for my purposes. I recommend that you take a look at the Carbotech Bobcats and some Brembo blanks.
Also what fluid is good? I have never really looked into changing it but it seems like it could have a huge imact.</TD></TR></TABLE>
ATE Superblue racing or ATE Type 200 Gold. Same fluid, just differnet colors. This fluid has a good wet and dry boiling point and is suitable for street driving. There are other fluids that are better, but they absorb moisture quicker, so the most practical choice for a dual purpose car.
Old Jan 1, 2004 | 09:30 PM
Soccerking3000's Avatar
Default Re: (kommon_sense)
i got brembo and they are sooo awesome u can stop on a dime with no problem, never have to worry about them warping such as happens with cheap ****, if u got the money go with brembo if not go with the gsr
lude rider
Nov 15, 2011 05:11 PM
cobra2326
Suspension & Brakes
Mar 7, 2006 04:35 PM
Big Phat R
Jun 11, 2003 03:21 PM
garados
Apr 23, 2002 04:48 AM
Reverend
Aug 30, 2001 08:16 AM
