how high should i rev??
Old Dec 30, 2003 | 09:57 PM
gsr98teg's Avatar
Default how high should i rev??
what is the highest recomended rpms that you should bring a stock gsr motor too
i am just curious wut you guys think of this
i have a jdm type r ecu in my car and i can bring it past 9k
if that safe??i have a stock b18c1, do u guys think that its a good idea to rev it that much
Old Dec 30, 2003 | 10:00 PM
Hairy Gorilla's Avatar
Default Re: how high should i rev?? (gsr98teg)
Def not a good idea for a stock GSR motor. Don't go past 8100. No reason to either. My GSR starts dropping in power after 7500 rpms and it has basic boltons. You will blow teh motor if you go much past 8100 unless you upgrade some parts...
SPOOLINVTEC
Guest
Posts: n/a
hey if you want a new set of valves sure ..rev it up to 10k b18c1 engines LOVE it
Old Dec 30, 2003 | 10:10 PM
gsr98teg's Avatar
Default Re: how high should i rev?? (spoolinvtec)
i am suprised that i havent blow it up already then b/c everytime i run it i rev that high
(normally shift at like 8900rpm) and it seems to be faster b/c when i shift into the next gear i am already in vtec which is nice and grab 3rd like a mother even wit a stock clutch wit 80k on it which is fun
Old Dec 30, 2003 | 10:13 PM
2G0S0R1's Avatar
New User
maybe like 8400 topps if stock cams/springs.
shifting at 7k will drop you above vtec too!
Old Dec 30, 2003 | 10:15 PM
xx dc2teg xx's Avatar
shift at 8900 then your next gear will be in vtec?
how do you feel faster?
any dyno will show you that the a stcok gsr will make peak power around redline which is 7800-8100ish. reving that high has no use what so ever especially on stock c1
CleenSi
Guest
Posts: n/a
Default Re: how high should i rev?? (2G0S0R1)
[QUOTE=2G0S0R1]maybe like 8400 topps if stock cams/springs.
shifting at 7k will drop you above vtec too![/ QUOTE]
...people who dont know this are just
errrr
nvm
Old Dec 30, 2003 | 10:16 PM
CrazyModGSR's Avatar
I have stock ecu and redline at 8100, and I can still shift and stay in VTEC.
Old Dec 30, 2003 | 10:17 PM
gsr98teg's Avatar
Default Re: how high should i rev?? (CleenSi)
my car opens vtec at 5800 and when i shift at like 7500 the next gear its at like 5k
Old Dec 30, 2003 | 10:19 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsr98teg &raquo;</TD></TR><TR><TD CLASS="quote">i am suprised that i havent blow it up already then b/c everytime i run it i rev that high
(normally shift at like 8900rpm) and it seems to be faster b/c when i shift into the next gear i am already in vtec which is nice and grab 3rd like a mother even wit a stock clutch wit 80k on it which is fun </TD></TR></TABLE>
Keep it up man..
Old Dec 30, 2003 | 10:21 PM
2G0S0R1's Avatar
New User
no! vtec is at 4400 rpm.
Intake air bypass system(secondaries) are opened at 5750... and those need a hard shift at 8100 to hold open, or maybe 8300/8400 with an easy shift.
Above that is a waste and dangerous unless you have cams/springs and some boltons.
Guaranteed.
Old Dec 30, 2003 | 10:22 PM
MyBigNut's Avatar
You've shown you don't know much about your car already... and this just further goes to show it.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by gsr98teg &raquo;</TD></TR><TR><TD CLASS="quote">my car opens vtec at 5800 and when i shift at like 7500 the next gear its at like 5k</TD></TR></TABLE>
Old Dec 30, 2003 | 10:28 PM
gsr98teg's Avatar
Default Re: how high should i rev?? (MyBigNut)
thanks
i admit when i am wrong
i am just out to learn more about cars and ****
i learn from my mistakes
since i dont know much about my car
when does the low cam switch to high?
and what is it that i hear changing over at 5800
and i thought that they changed the dual stage vtec on te type r to a single stage??
correct me WHEN i am wrong
Old Dec 30, 2003 | 10:35 PM
2G0S0R1's Avatar
New User
I just answered those q's 2 posts above you, and yes thay changed the ITR to a single intake runner manifold (vtec is "single stage" in all b18c1/5's)
AND... im suprised your "JDM ITR ECU" is controlling the runners anyway, you sure its not just a chipped p72?
Old Dec 30, 2003 | 10:38 PM
gsr98teg's Avatar
ahhh i seeeee
interesting
so howcome the car pulls a lot harder at 5800 then it does at 4400
Old Dec 30, 2003 | 10:44 PM
2G0S0R1's Avatar
New User
the stock b18c1 camshaft profile combined with the 10:1 compression ratio requires more air around 5500 rpms to make the power transition from the torque curve to the HP curve.
The vtec helps little in the low rpms, so there is no real "kick" in the low range.
The power curve combined with the shorter intake path allows a "kick" in the high rpms.
The vtec does help more in the long run... try disabling it and reving to 8k
But, unhook the secondaries and it still gets there fairly quick.
Old Dec 30, 2003 | 10:47 PM
2G0S0R1's Avatar
New User
and dropping the point of your secondaries opening to about 5500rpms helps to stay in that range when you shift at around 8k.
Any lower than 5400rpms and you lose torque and MPG.
Old Dec 30, 2003 | 10:59 PM
Kwuaymaikrup's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by MyBigNut &raquo;</TD></TR><TR><TD CLASS="quote">You've shown you don't know much about your car already... and this just further goes to show it.
Did you stop to think that maybe, just maybe his ecu moved the vtec activation as it did the redline?
Old Jan 4, 2004 | 12:28 AM
MyBigNut's Avatar
Default Re: how high should i rev?? (Kwuaymaikrup)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Kwuaymaikrup &raquo;</TD></TR><TR><TD CLASS="quote">
Did you stop to think that maybe, just maybe his ecu moved the vtec activation as it did the redline?</TD></TR></TABLE>
Well... Seeing as he said he has a JDM Type R ECU...it would be running from the single stage VTEC program, correct?
So maybe...just maybe... his ECU DIDNT move the vtec activation point as it did the redline?
Old Jan 4, 2004 | 12:35 AM
So maybe...just maybe... his ECU DIDNT move the vtec activation point as it did the redline?</TD></TR></TABLE>
True...I was thinking Mugen program and didn't realize that he had the Type R ecu. My Mugen chipped ecu for my old setup had the same rev limit but a 5,400 vtec activation. So maybe, just maybe...you are right
Old Jan 4, 2004 | 10:07 AM
thegsrman's Avatar
you probably wont make any power past 7600 rpm. might need to upgrade your valve train (cams, valve springs and retainers,etc) maybe cam gears , also tune your car maybe on a dyno to get the most out of mods and xtra rpm.
Old Jan 4, 2004 | 10:16 AM
P1mpSlap's Avatar
Rev it to 8200 and you'll be fine. The point where you drop off after you shift is where it counts.
My GSR when it was stock made power well into the high 7s so I just took it a bit higher so the RPMs wouldn't fall that far after I shifted.
Mr. DeOro
Aug 16, 2009 04:55 PM
97grnrs
Apr 5, 2008 06:57 PM
aznsmtboy
15
May 29, 2004 10:22 PM
RudeLude
Mar 4, 2003 11:45 PM
E46M3CB
Feb 28, 2002 11:09 AM
