CTR CAMS vs ITR CAMS
Old Dec 30, 2003 | 08:48 PM
lo0nY's Avatar
Default CTR CAMS vs ITR CAMS
Already searched....can't find a definite answer.... trying to find out if the 01+ ITR CAMS are the same as CTR cams.....say a set of +01 ITR cams for $299.99.... anyone know for sure?
Old Dec 30, 2003 | 09:03 PM
IS3Fifty's Avatar
Default Re: CTR CAMS vs ITR CAMS (lo0nY)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lo0nY &raquo;</TD></TR><TR><TD CLASS="quote">Already searched....can't find a definite answer.... trying to find out if the 01+ ITR CAMS are the same as CTR cams.....say a set of +01 ITR cams for $299.99.... anyone know for sure? </TD></TR></TABLE>
Nope, not for Intake side at least. The CTR intake cam has higher durations over the ITR intake cam. As for the exhaust cams they are basically the same cam.
Old Dec 30, 2003 | 09:09 PM
TwistedSI's Avatar
I've heard both. That the CTR is more aggressive and that the ITR is more aggressive. Seems the only thing anyone can agree on is that the exhaust cam is the same. I honestly don't think anyone really knows.
All I know is that the only person I would ever let touch my car says that he was told the ITR's were more aggressive but he wasn't real sure either. The one thing he says he does know is that the ITR's tend to yield better results for him in all motor applications and that is what he recommended me to get. I have never second guess him as I consider him one of the best Honda guru's I know so that is why I have the ITR's sitting here in their boxes waiting for cam gears to go in.
Old Dec 30, 2003 | 09:16 PM
SOUNDEFFECTS's Avatar
Default Re: (TwistedSI)
CTR intake cams have 3 degrees more duration and a a couple more degrees of overlap. They are more of an aggressive cam. They will yield higher HP results over the ITR intake cam.
Old Dec 31, 2003 | 03:55 AM
Xsi's Avatar
Xsi
The exhaust cams are the same, the CTR intake cam up to 2000 are slightly more aggressive.
2000+ B series ITR and CTR are both the same.
Modified by Xsi at 11:56 AM 12/31/2003
Old Dec 31, 2003 | 06:03 AM
sledgehammer's Avatar
+01 ITR cams = CTR cams
older ITR cams &lt; CTR cams (sighting that infamous 3 degrees)
Mike
Old Dec 31, 2003 | 07:57 AM
sikciv666's Avatar
Default Re: CTR CAMS vs ITR CAMS (sledgehammer)
[QUOTE=sledgehammer]
thats what I tell everyone
Old Dec 31, 2003 | 09:24 AM
Kool305's Avatar
the set up most people run is CTR intake cam/ITR exhaust...
apparently from what i've heard CTR/ITR exhaust cams are THE SAME...
correct me if im wrong...peace
Old Dec 31, 2003 | 01:56 PM
jdmsiR20's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sledgehammer &raquo;</TD></TR><TR><TD CLASS="quote">
Mike</TD></TR></TABLE>
Old Dec 31, 2003 | 09:03 PM
lo0nY's Avatar
does anyone know for sure?
Old Dec 31, 2003 | 09:17 PM
spnfed's Avatar
ITR int cam part # 14111-p73-j00
ITR exh cam part # 14121-p73-j00
CTR int cam part # 14111-pct-000
CTR exh cam part # same as ITR 14111-p73-j00
JDM ITR int specs 240 deg of intake duration, 11.5mm lift
JDM ITR exh specs 235 deg of duratio ,10.5mm of lift
ITR have 25 degrees of overlap
CTR int specs 243 degs of duration and 28 degrees of overlap.
Hope that helps.
Old Dec 31, 2003 | 09:38 PM
TwistedSI's Avatar
Default Re: CTR CAMS vs ITR CAMS (spnfed)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by spnfed &raquo;</TD></TR><TR><TD CLASS="quote">ITR int cam part # 14111-p73-j00
Hope that helps. </TD></TR></TABLE>
Those appear to be the "older" ITR intake cam. The part numbers for the 2001+ are:
2001+ ITR Intake Cam 14111-P73-J01
2001+ ITR Exhaust Cam 14121-P73-J00
Old Dec 31, 2003 | 09:39 PM
TwistedSI's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by lo0nY &raquo;</TD></TR><TR><TD CLASS="quote">does anyone know for sure? </TD></TR></TABLE>
No
Old Jan 1, 2004 | 01:09 AM
lo0nY's Avatar
Default Re: CTR CAMS vs ITR CAMS (TwistedSI)
i'm lost..........is there a HONDA mechnic that knows for sure..........
Old Jan 1, 2004 | 02:41 AM
rodrez.'s Avatar
If you found a good deal on 01 ITR cams, just pick them up. The difference between the CTR intake cam and the 01 ITR cam is so minimal, that it won't make much difference.
Bottom line, we know for sure that the 01 ITR intake cam is bigger than the older one. The exhaust cams for all of the above mentioned are the same.
Old Jan 1, 2004 | 03:07 AM
poetter's Avatar
Default Re: CTR CAMS vs ITR CAMS (rodrez)
as for the best setup, the guys that wrote above me are right. the best intake cam to use is the CTR. it has more duration and overlap (better high rpm). and as for the exhaust. between the two, its really not going to affect much. use whichever you can get your hands on. if youre looking for duration or overlap, i can help you with the ITR, i work at an acura dealership. let me know what you need.
Old Jan 1, 2004 | 04:02 AM
Ausmith's Avatar
Answering your question directly - yes, 01+ ITR Cams have the same specs as CTR Cams. Both have 3 degrees more duration on the intake cam when compared to the 96-98 ITR intake cam.
$300 is a pretty decent deal.
Old Jan 1, 2004 | 11:02 AM
supaZZZleepa's Avatar
yes ctr intake cam is more aggresive. i have that on my b18c5 and it feels slightly more aggressive than the itr intake cam...however the exhaust cam of the itr and ctr are the same.
Old Jan 1, 2004 | 11:09 AM
Filliam H. Muffman's Avatar
Default Re: (supasleepa)
i think we got the required info down, now let the thread die
Old Jan 1, 2004 | 11:16 AM
WongFeihung's Avatar
Default Re: (JUN EK9)
good post actually. learned somthing new
Old Mar 7, 2004 | 10:52 PM
1SlowSi's Avatar
Default Re: (WongFeihung)
Well lemme ask something... So ALL years of the CTR cams are the same... the ITR's are the only ones to change? i thought it was 2000-2001... what years were different? thats what im lost on.
Old Mar 7, 2004 | 10:57 PM
spnfed's Avatar
Default Re: (1SlowSi)
As far as I know the CTR's are the same 96-00.
Old Mar 7, 2004 | 11:20 PM
rodrez.'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1SlowSi &raquo;</TD></TR><TR><TD CLASS="quote">Well lemme ask something... So ALL years of the CTR cams are the same... the ITR's are the only ones to change? i thought it was 2000-2001... what years were different? thats what im lost on. </TD></TR></TABLE>
CTR cams didn't change. ITR cams on the new model ITR's have a larger intake cam that is almost identical to CTR cams of all years.
Old Mar 8, 2004 | 04:52 AM
TwistedSI's Avatar
Well, even though this thread has been beaten to death and no one will believe anything anyone says. A friend showed me some Honda spec sheets a couple weeks ago and it showed the 01+ ITR cams having a hair more duration than CTR cams. Which makes sense since the ITR is a bigger displacement motor.
Old Mar 8, 2004 | 05:18 AM
1SlowSi's Avatar
i see all this 01+ 01+ dont you mean 2000-2001? there isnt any plus anything. 01 was the last year.
