Those with 98-01 OEM/Type-R Lip
Old Dec 30, 2003 | 08:47 PM
N1NjA TuRtLE's Avatar
Default Those with 98-01 OEM/Type-R Lip
i just recently bought the lip from a fellow H-T member. He gave me 4 screws which were for the left and right side.
I would like to know if it's safe driving with just those 4 screws or should i get
the 8 other screws that come from under the lip? If so, What size are the nuts/screws sizes? And where can i get em? Also, i was told that i'll need 3M tape, and what else?
Old Dec 30, 2003 | 09:03 PM
wanna b R's Avatar
Default Re: Those with 98-01 OEM/Type-R Lip (4DoorGeezer)
i use zip ties and 2 screw on each side and 3m tape...
Old Dec 30, 2003 | 09:09 PM
SilverDc2's Avatar
Default Re: Those with 98-01 OEM/Type-R Lip (wanna b R)
OEM lip
Old Dec 30, 2003 | 09:14 PM
Default Re: Those with 98-01 OEM/Type-R Lip (SilverDc2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SilverDc2 &raquo;</TD></TR><TR><TD CLASS="quote">OEM lip </TD></TR></TABLE>
LMAO, thanx Paul
Old Dec 30, 2003 | 09:15 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by wanna b R &raquo;</TD></TR><TR><TD CLASS="quote">i use zip ties and 2 screw on each side and 3m tape...</TD></TR></TABLE>
ahh i c, i might just use zip ties also
Old Dec 30, 2003 | 09:16 PM
anyone else?
Old Dec 30, 2003 | 09:22 PM
Old Dec 30, 2003 | 09:36 PM
no more suggestions?
Old Dec 30, 2003 | 09:39 PM
QTKEG6's Avatar
go to home depot, get 10mm bolts about 1/2" long w/ washers
Old Dec 30, 2003 | 11:07 PM
98gsrTEG's Avatar
Default Re: Those with 98-01 OEM/Type-R Lip (QTKEG6)
i used all the bolts, but when my bumper was off for the turbo install, i lost most of the bolts, so zip ties it is for me. its worked so far
Old Dec 30, 2003 | 11:12 PM
fergy016's Avatar
Default Re: Those with 98-01 OEM/Type-R Lip (98gsrTEG)
get some body kit tape from 3m and bolt just the ends where the tires are and it should be fine.
Old Dec 30, 2003 | 11:35 PM
non_VTEC's Avatar
Default Re: Those with 98-01 OEM/Type-R Lip (fergy016)
I went to the acura and pick up a bunch of the bolts and clip nuts. I dont remember how much they were, but if you tell them you need the bolts and nuts for the OEM lip, they should know what you are looking for. I used 3M tape with the nuts. Hope that helps!
Old Dec 30, 2003 | 11:49 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by QTKEG6 &raquo;</TD></TR><TR><TD CLASS="quote">go to home depot, get 10mm bolts about 1/2" long w/ washers</TD></TR></TABLE>
thanx
Old Dec 30, 2003 | 11:50 PM
Default Re: Those with 98-01 OEM/Type-R Lip (non_VTEC)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by non_VTEC &raquo;</TD></TR><TR><TD CLASS="quote">I went to the acura and pick up a bunch of the bolts and clip nuts. I dont remember how much they were, but if you tell them you need the bolts and nuts for the OEM lip, they should know what you are looking for. I used 3M tape with the nuts. Hope that helps! </TD></TR></TABLE>
Wow from acura, wouldn't it be too expensive?
Old Dec 31, 2003 | 12:01 AM
non_VTEC's Avatar
Yeah it might be a little pricey. We all know Acura over charges, but i wanted my lip nice and secure. It adds a bit of secuity too because it takes longer to remove, so i think its worth it.
Old Dec 31, 2003 | 04:46 AM
IMPATIENT's Avatar
i used self tapping screws on the bottom of the lip, and the regular screws that are used on the side.........
Old Dec 31, 2003 | 08:54 AM
GSRacer93's Avatar
Default Re: Those with 98-01 OEM/Type-R Lip (IMPATIENT)
wouldn't zipties be pretty safe? because if it were to get ripped off the car while driving, it would get ripped off in one piece. my friend did this for his civic and he said it's save his lip a couple times.
Old Dec 31, 2003 | 05:15 PM
[jdm ap2]'s Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 4DoorGeezer &raquo;</TD></TR><TR><TD CLASS="quote">i just recently bought the lip from a fellow H-T member. He gave me 4 screws which were for the left and right side.
the 8 other screws that come from under the lip? If so, What size are the nuts/screws sizes? And where can i get em? Also, i was told that i'll need 3M tape, and what else? </TD></TR></TABLE>
i wouldn't say its safe... i mean you could drive it... it wont fall off... but just talking from experience... 4 screws take about 2 minutes to take off... with 2 guys.. and itr lip with only 4 screws is asking for it... i had mine stolen with all the screws on .. let alone 4.. id say glue it down.. lol j/p.. but just because there are these ****** snake thieves around.. use all screws.. it would be harder to steal... kinda sucks to come out and see ur lip taxed...
Old Dec 31, 2003 | 05:28 PM
integraL's Avatar
Default Re: Those with 98-01 OEM/Type-R Lip ([jdm dc2])
competech lip is cool too!!
Old Dec 31, 2003 | 05:49 PM
SIK IN DA HED's Avatar
New User
just get some screws and nuts to hold it down from home depot.
Old Dec 31, 2003 | 05:56 PM
iam7head's Avatar
Default Re: Those with 98-01 OEM/Type-R Lip (integraL)
Invests in a bolt and nuts set up, a pack of washers, double nuts or locking nuts and bigger bolt doesnt cost much at homedepot
because you cant dodge all the ditch and bumps
Old Dec 31, 2003 | 06:44 PM
IntegraXTR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by integraL &raquo;</TD></TR><TR><TD CLASS="quote">competech lip is cool too!! </TD></TR></TABLE>
word..all i am using is the double sided tape that came with it haha..
it held when i test fitted it!
Old Dec 31, 2003 | 10:04 PM
Huh_oh Shit!'s Avatar
Use some screws and GOOP it! It has worked wonders for my cousin's side skirts and rear lip for his civic so far (2.75 years).
Old Jan 1, 2004 | 03:55 AM
alfaaay's Avatar
Default Re: (Huh_oh ****!)
I have 2 screws on each side where it meets the fender, and I have two bolts on the bottom. That bitch ain't going nowhere.
I think it's okay to just have the side screws because that's how the Comptech lips are suppposed to be installed. However, having just side screws makes it easier to jack.
Old Jan 1, 2004 | 07:07 AM
beaterman's Avatar
Default Re: (alfaaay)
all i have on mine is the side screws in. the lip fits so snug against the front end i did not think that the other bolts where needed.
