Crower 404 cams clearance with stock pistons
Old Dec 30, 2003 | 08:41 PM
specie's Avatar
Default Crower 404 cams clearance with stock pistons
I have a ls head that's been milled .03" (just to clean it up) and was thinking about putting the head with Crower 404 cams on a stock LS block. I was wondering if there is going to be clearance problems. I have a spare block that I'm going to put in Wiseco pistons, but I wanted to experiment with nitrous on the stock block before putting in the built block. Share your experience.
Are the valve reliefs on the stock pistons deep enough to prevent piston-valve contact?
Old Dec 30, 2003 | 11:31 PM
10secondhatch
Guest
Posts: n/a
Default Re: Crower 404 cams clearance with stock pistons (specie)
.030 is more than just cleaning up. When you resurface a head its more like .003 to .005. As far as the piston to valve clearance, if the head is milled .030 you should definitly clay test the motor. Having an LS head makes that job even easier.
Old Dec 30, 2003 | 11:40 PM
mtber's Avatar
specie,
I live in palm harbor & have a b18b head f/s :-)
95 b18b Cylinder Head (Stamped 94 like all 95 b18b heads)
$80 for the cylinder head with:
Valvetrain, Cams, Cam Pulleys, Valve Cover, intake manifold, JDM b18b cams out of my old 98 b18b into this head.
mtber's Avatar
i have imed you my #
The head has never been milled :-)
Old Dec 31, 2003 | 06:46 AM
LODOSS's Avatar
Default Re: (mtber)
i had 403s with about .3 milled head and it was ok but between 403 and 404 there is a good amount of difference i would def do it just to be on the safe side.
Old Jan 7, 2004 | 07:06 PM
JdM_Eg_6's Avatar
Default Re: (mtber)
hey what up do u still have that b18b head, if so let me know because i will buy it!!!!!!!!
Vspronk
Oct 20, 2015 10:35 AM
VTECROAR96typeR
Dec 28, 2008 06:01 AM
Em0ne
Mar 22, 2004 02:29 PM
redEFnine
Jul 9, 2003 10:35 PM
Regular Series
Dec 3, 2002 06:42 AM
