any thoughts on the endyn crankcase breather?
pros/cons/thoughts?
Tryin to get all the input I can before I make a choice on a breather/catchcan
Looks like its better than the greddy one, just because it breathes as opposed to being closed.
If it is a vtec head on a b20 block, or 98 up LS, there is nothing that your 100-150 would be better spent on. If you plan ahead for power, you will run into fewer pitfalls. (better ring seal>less blow by>allows more combustion pressure to be transmitted to the crank)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sgT »</TD></TR><TR><TD CLASS="quote">moroso catch can
the endyn one is a modified version of that...haha...so if I have a 93 LS block, I shouldsent need this? I just want things to be safe and clean as possible..
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by chris@allmotor.net »</TD></TR><TR><TD CLASS="quote">
the endyn one is a modified version of that...haha...so if I have a 93 LS block, I shouldsent need this? I just want things to be safe and clean as possible..</TD></TR></TABLE>
From what I am able to gather, from looking at PIX ONLY.... never held ether Endyn modded or Moroso can....
but it looks like the Moroso one just has an extra hole tapped into it.
The breather tanks our systems have been supplied with for the last couple years have dual welded-in inlet ports. As of four months ago, all our tanks have also come with universal mounting brackets, rather than a simple welded-on strap (like the Moroso units).
One of these days we'll update the pictures.....
but its hookups look like they make sense...
