ported head now having idle problems.
Old Dec 30, 2003 | 06:43 PM
vtecmissle's Avatar
Default ported head now having idle problems.
i ported my head myself and after reassembling the engine i am having serious problems. my idle is at 2000 rpm or higher and i cant seem to find the trouble. is this a common occurance or what . any help would be greatly appreciated. as always thanks.
Old Dec 30, 2003 | 06:49 PM
jdmotorsports's Avatar
Default Re: ported head now having idle problems. (vtecmissle)
p&p doesnt affect idle at all. i would check other things. vacuum lines, idle control, and make sure all connections are ok.
Old Dec 31, 2003 | 03:50 PM
importimage's Avatar
Default Re: ported head now having idle problems. (jdmotorsports)
IAC Valve, FIT Valve, TPS sensor, Vac leak. Let me know via PM if more problems!
Old Dec 31, 2003 | 03:59 PM
P1mpSlap's Avatar
Default Re: ported head now having idle problems. (importimage)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by importimage &raquo;</TD></TR><TR><TD CLASS="quote">IAC Valve, FIT Valve, TPS sensor, Vac leak. Let me know via PM if more problems!</TD></TR></TABLE>
Yup. Make sure they are all connected correctly and the timing is dead on.
Old Jan 1, 2004 | 11:02 PM
vtecmissle's Avatar
Default Re: ported head now having idle problems. (P1mpSlap)
Thanks for all the help guys. here is the deal it was a broken junk autozone pcv valve. but i thought it might be sensors before i posted and mixed them up thinking they were wrong. i realized it was vacuum problems when i unhooked the iac valve and the engine idled very well. so i knew then that it was getting air to run from the vacuum lime. i also got some help from INVTEC on this board who suggested that i had a massive vacuum leak and told me what rpms i was running and why they would suggest that particular problem. all advice given was helpful thanks. i would also like to say that i searched through over a hundred threads of a similar nature and could have been helped there if the poster needing the help told everybody how the problem was solved. most did not it ended with another members suggestions and no correspondence from the poster that was very frustrating and a kick in the *** to all the people who generously jumped in to help. i apreciate your help very much as thinking my car was fucked severely traumatized me.....
Old Jan 2, 2004 | 11:50 AM
no prob. glad it turned out to be a cheap fix.
shifts
Apr 28, 2007 11:11 AM
darkstar90
Apr 26, 2007 10:57 PM
DxTrix
Dec 24, 2003 08:59 PM
1.8T_EG
Oct 27, 2003 06:20 PM
LD_EGSICK
15
Aug 5, 2003 10:35 PM
