swapping a d16y8 into my VX hatch where can i find HARNESS to convert to OBD2???
Old Dec 30, 2003 | 05:43 PM
s2000june's Avatar
Default swapping a d16y8 into my VX hatch where can i find HARNESS to convert to OBD2???
hey im swappin out my sohc VTEC economy motor for a d16y8
and i needa know where i can get a harness so i can put this motor in.
im gonna have to convert to 0b2 so i need 1 of them converters from obd1 too obd2
if anybody knows any sites or can help me out with this it will be greatly appreciated!!
later
Old Dec 30, 2003 | 05:44 PM
ng's Avatar
ng
Default Re: swapping a d16y8 into my VX hatch where can i find HARNESS to convert to OBD2??? (civicrida3)
https://honda-tech.com/zerothread?id=681096
Old Dec 30, 2003 | 07:08 PM
zer0.'s Avatar
why would you want to convert to OBDII from OBDI?
Old Dec 30, 2003 | 07:24 PM
s2000june's Avatar
because the d16y8 is obd2
and my car is obd1
so i needa switch the harness to use this motor
Old Dec 30, 2003 | 07:33 PM
cjames235's Avatar
Default Re: (civicrida3)
Y would u convert your harness to obd2 I would leave it obd1.
Old Dec 30, 2003 | 10:41 PM
salbaje's Avatar
just use your original harness. you dont need to convert it to obd2.
Old Dec 31, 2003 | 04:37 AM
cjames235's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by civicrida3 &raquo;</TD></TR><TR><TD CLASS="quote">because the d16y8 is obd2
and my car is obd1
so i needa switch the harness to use this motor</TD></TR></TABLE>
you dont need the obd2 harness to run the engine.... all the plugs from your existing harness will plug into the engine. as far as what ecu to use....... p28
Old Dec 31, 2003 | 10:38 AM
s2000june's Avatar
thanks FOR YALL HELP
u just saved me money that i wouldnt of had 2 spend
i just need a ECU now but i think i have 1
Old Dec 31, 2003 | 10:42 AM
oldbeefcake's Avatar
don't forget your O2 sensor wires.
Old Dec 31, 2003 | 11:04 AM
B18C5-EH2's Avatar
Former Moderator
Loved
Yes keep your engine harness and run a 1992-1995 D16Z6 P28 ECU.
The only wiring changes I can think of will be your o2 sensor wiring because your VX uses a 5-wire o2, and the D16Y8 will use a 4-wire o2 sensor.
Also you'll need to either use a 1992-1995 Si/EX distributor OR simply move two wires over from the one plug on the Y8 dizzy into the extra plug on your engine harness.
I've got pics of that since I had to do the same thing on the B16A2 dizzy with the OBD1 Z6 engine harness in my fiancee's 1992 Si.
Also you need to keep the VX alternator too because the plug on the Y8 alternator won't match the D15Z1/Vx engine harness.
There's one more small change, but I need to IM Kenji for it.
Old Dec 31, 2003 | 11:19 AM
B18C5-EH2's Avatar
Former Moderator
Loved
Here's those pics that I took:
Also the intake air temp sensor is in your manifold on the OBD1 engine. On the D16Y8 it's on the intake tubing, so you'll need to extend the wires for the IAT sensor like so:
It might look hard, but trust me it's really easy. The dizzy wires are the same exact color, and extending the IAT wires is as easy as soldering and taping two wires.
That should be it, but if I think of anything else I'll let you know.
Converting to OBD2 is SHITTY.
OBD2 sucks ***. It throws more CELs than OBD1 ever will, and they also have totally sensitive readings for o2 as well. They throw random misfire codes, secondary o2 codes (OBD1 only uses 1 o2 sensor), etc.
In a nutshell keep your OBD1 harness and an OBD1 P28 ECU and you'll get more power and less CELs out of that D16Y8.
Old Dec 31, 2003 | 11:48 AM
SOHC_MShue's Avatar
Default Re: swapping a d16y8 into my VX hatch where can i find HARNESS to convert to OBD2??? (B18C5-EH2)
yea obd2 blows
Old Dec 31, 2003 | 12:06 PM
s2000june's Avatar
HEY thanks alot guys
really needed the help
im gonna use my ECU from my 94 ex coupe
the p28
thanks alot
Old Jan 2, 2004 | 12:34 PM
B18C5-EH2's Avatar
Former Moderator
Loved
bump
Old Apr 29, 2004 | 08:37 PM
ninety9ex's Avatar
awesome post... this deserves to go back up!
Old Apr 30, 2004 | 06:46 AM
nightshocker's Avatar
Just a FYI for all you guys doing this swap. Find a 1.5 Dizzy from a 92-95 civic. It bolts right up to the d16y8 head. And walla you have odb1.
Old Apr 30, 2004 | 07:52 AM
EK_Civic_Man's Avatar
I have mad part for D16y8 if needed
Old Apr 30, 2004 | 08:08 AM
Smith Wise's Avatar
Default Re: (EK_Civic_Man)
so could i use an obd2-&gt;obd1 conversion harness, dx obd1 ecu to rid myself of this pesky secondary o2 issue I'm having in my 99 y7, and still pass emissions?
jazzRS
Sep 28, 2012 03:16 PM
The93egg
Aug 24, 2009 04:20 PM
too much vtAK
Feb 13, 2006 02:49 PM
95vr6man
Feb 5, 2006 10:03 AM
Henry HA
10
Jan 7, 2004 08:33 AM
