What is this and why isn't it hooked up?
Old Dec 30, 2003 | 12:55 PM
The_Todd's Avatar
Farts in the shower
Default What is this and why isn't it hooked up?
I was cleaning my car and engine today and noticed this, looks like a heater return line or something....but what does it do and why isn't it hooked up? And this is on the passenger side of the car by the firewall.
And lastly, which one is my IACV, looking around and looked in my Chiltons no dice:
Thanks for the help
Old Dec 30, 2003 | 03:53 PM
The_Todd's Avatar
Farts in the shower
Default Re: What is this and why isn't it hooked up? (VRDrvr)
Bump...no one knows?
Old Dec 30, 2003 | 03:58 PM
89_LXi's Avatar
Does that hose have a clamp on it? Towards the bottom of the firewall? It's most likely the A/C evaporator drain tube, which just lets the water from the evaporator drain out onto the ground
Old Dec 30, 2003 | 04:00 PM
The_Todd's Avatar
Farts in the shower
Default Re: What is this and why isn't it hooked up? (89_LXi)
Its at the bottom of the firewall on the passenger side, and I didn't see any clamps or hoses to where this may or may not lead
Old Dec 30, 2003 | 04:14 PM
DrunkNRacer's Avatar
Its A/C Evaporator Tube for sure.
evaporator is used to turn that liquid refrigerant into a vapor, allowing it to absorb heat and carry it away from the cabin .. the tube is to drain excess water from evaporator.
Old Dec 30, 2003 | 04:33 PM
The_Todd's Avatar
Farts in the shower
Default Re: What is this and why isn't it hooked up? (DrunkNRacer)
So its supposed to just sit there and spill over excess coolant? Or should a line be running to/from it? And on the 3rd pic...which one is it or am I just plain dumb? (that ? was retorical)
Old Dec 30, 2003 | 04:55 PM
89_LXi's Avatar
It doesn't spill coolant, it's just plain water.... and yes, it's supposed to drain right out onto the ground. Exactly the same way a room air conditioner or de-humidifier in your house works. The water is formed by condensation from when warm air passes over a really really cold evaporator core... same way a cold drink will "sweat" when it's warm out and make the outside of the glass all wet. The water has to drain out or the evaporator will turn into one big ice block, LOL
Old Dec 30, 2003 | 04:58 PM
The_Todd's Avatar
Farts in the shower
I knew the a/c systems were kinda the same, I just saw an open line and my jaw dropped......thank you, and what about the 3rd pic with the IACV any suggestions?
Old Jan 1, 2004 | 10:03 AM
EMI's Avatar
EMI
i think it is the evaporator tube
Old Jan 1, 2004 | 03:40 PM
ChaosUnbound's Avatar
iacv is on the far left
h4x
Sep 11, 2012 05:08 PM
RicharDC4
May 27, 2009 05:45 PM
Paul*DC4
Jul 12, 2008 11:45 PM
Ritchie
Dec 22, 2006 08:12 PM
tuan...
Jan 21, 2004 05:50 PM
