JDM H22 bottom block?
I'm in the process of modifying my JDM block and would like to know what combo's should I do. I'm go NA and the car is daily driven, this is what I have now for my mods:
Port & Polished head
Crower valvetrain
Skunk stage 1 cams (soon to be stage 2)
aem camgears (soon to be skunk2)
RC injectors
JG throttle body
JDM H22 intake manifold (soon to be P&P)
milled head (.030)
p28 w/ skunk chipped (going to get my hondata s100 back in a few days)
DC headers (soon to be hytech or DTR)
ACT 6 puck
5 zigen catback
JDM stock block
I plan to be running 13s so what do you guys think what combos to go with.
Crower valvetrain
RC injectors
JG throttle body
milled head (.030)
ACT 6 puck
5 zigen catback
JDM stock block
What are u hittin now? Is it a 4th or 5th gen? If it's a 4th gen then i would get a greddy header. Dont forget a lsd. why are u changing cam gears? That should net u low 13 with some sticky tires if u can drive.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by flip1199 »</TD></TR><TR><TD CLASS="quote">What are u hittin now? Is it a 4th or 5th gen? If it's a 4th gen then i would get a greddy header. Dont forget a lsd. why are u changing cam gears? That should net u low 13 with some sticky tires if u can drive.</TD></TR></TABLE>
Dude my power sucks for some reason, its only putting 178 hp w. 154 tq. only put out 14.9 at 93 mph. The motor is in the 4th gen 96 body....... Low 13s? I doubt it will hit low 13s that's impossible for that kind of set up only.... Look at Satan-SV or something, i forget what his name is but I don't even have all that kind of mod and he's pulling mid 13s
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 2.2Lcivic »</TD></TR><TR><TD CLASS="quote">get some rods and pistons... high compression.(12.5:1 or higher)</TD></TR></TABLE>
What he said, and more fuel
https://honda-tech.com/zerothread?id=395353
I think there's either something wrong with the motor or driver. Most guys i've seen with 4th gen vtec's hit around 15 flat stock and mid to high 14's with bolt-ons around sea level. What did the rest of the slip look like?
Modified by flip1199 at 3:43 PM 12/30/2003
