shoo wee doggies! my b16a swap doin some wierd stuff
Old Dec 30, 2003 | 09:54 AM
b16acrxer's Avatar
Default shoo wee doggies! my b16a swap doin some wierd stuff
in my b16a powered 90 crx dx: sometimes when i touch the brakes when driving my radio will cut off and or my tach will touch down to 0 rpms until i let off the brakes. what up with dat homie?
thanks
Old Dec 30, 2003 | 10:15 AM
tim_adams85's Avatar
Default Re: shoo wee doggies! my b16a swap doin some wierd stuff (b16acrxer)
Hahaha, I have a similar situaton.... every once in a while, when making left hand turns, my dome light will turn on, then off again once I straighten the wheel. I too have a b16a swap, just in a civic dx. I figured it was a jdm thing y0!
Old Dec 30, 2003 | 10:47 AM
virginia_dude's Avatar
check your wiring, you may have something loose or a bad ground. grab and wiggle things whith engin running see if you an find it that way first.
Old Dec 30, 2003 | 01:30 PM
USDM 4G VTEC's Avatar
BAD GROUNDS
i can bet 5 bucks in dat
check alllllllllllllll ur grounds...... clean them all, make sure u got them all tight and that none is missin
Old Dec 30, 2003 | 01:59 PM
kaosbob's Avatar
Default Re: shoo wee doggies! my b16a swap doin some wierd stuff (virginia_dude)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by virginia_dude &raquo;</TD></TR><TR><TD CLASS="quote">check your wiring, you may have something loose or a bad ground. grab and wiggle things whith engin running see if you an find it that way first.</TD></TR></TABLE>
good way to get knocked on your ***. Try getting a voltmeter and checking it the right way.
Old Dec 30, 2003 | 03:47 PM
LudeEFv2.4's Avatar
My old title sucked.
Default Re: shoo wee doggies! my b16a swap doin some wierd stuff (kaosbob)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by kaosbob &raquo;</TD></TR><TR><TD CLASS="quote">
good way to get knocked on your ***. Try getting a voltmeter and checking it the right way.</TD></TR></TABLE>
i totaly got a mental image of that, thanks you almost knocked me off my chair.
Old Dec 31, 2003 | 08:22 AM
b16acrxer's Avatar
oh yeah i forgot to mention that my battery has been relocated to the rear of the car and is grounded to the chassis where the taillight bolt in....same is in my last crx. i didnt have this problem in that car however...
Old Jan 21, 2004 | 09:55 AM
b16acrxer's Avatar
oh yeah ive also got a lot of chiming on the passenger side of the car...almost all the time....whats going on with it...
Old Jan 21, 2004 | 10:20 AM
You are a wussy man if 12v knocks you on your ***. Grab a spark plug wire on a running engine once, THAT knocks you on your ***. (that wasn't by choice was a motorcycle that had a throttle stuck wide open and was stuck in gear.) Now there is something that will curl your hair if anything will.
Old Jan 21, 2004 | 12:35 PM
b16acrxer's Avatar
who gives a crap what knocks you on your ***? i wanna know why my car's acting up! i know how to not be shocked. thanks in advance...
ronnie
Old Jan 21, 2004 | 01:59 PM
Kasper.'s Avatar
You really shouldnt have to worry about getting zapped big time by doing the wiggle test, its a great test by the way one I use i the shop everyday, but to do it of course you need the circuit to be powered.
Just sounds like a power or ground is shorted, did you do anythign with your brake switch? pedal? column? anything under the dash?
Like everyone else said, this is a human error and you need to find it yourself, theres really no way to just say oh this is whats happening.
Good luck with it!
PS-I was adjusting my buddies timing on his 350 in a t-bucket and was rotating the Dizzy by holding it by the top(right where the coil is) that is a bad idea, I turned it a quarter turn and pretty much **** my pants, it doesnt knock you back but It sends a nice spike through your whole body(thats 50,000 kv with an msd setup)
remember its not volts that kill you its amps.
Old Jan 21, 2004 | 03:47 PM
regime's Avatar
Default Re: shoo wee doggies! my b16a swap doin some wierd stuff (KasperFFTI)
haha i had the same prob with my crx with a b16. i took a left corner and my right ball started to hurt.. then i hit a curb sideways and my back hurt... just kidding guys... like they said its the grounds heheh
Old Jan 22, 2004 | 03:49 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b16acrxer &raquo;</TD></TR><TR><TD CLASS="quote">who gives a crap what knocks you on your ***? i wanna know why my car's acting up! i know how to not be shocked. thanks in advance...
ronnie</TD></TR></TABLE>
You know what you need to do? Grow up and stop being such a smartass. You need to curb that attitude and do it quickly, it will get you nowhere fast. I have 25 years in the electronics industry, 12v is not going to knock anyone on their ***. Unless that 12V is applied sub-dermally.
Wiggling the wires is the first thing any technician that is presented with an intermittant problem is going to do. You have to get the item into a failure mode and figure out if its intermittant or not. Before you can even begine to narrow it down.
Old Jan 22, 2004 | 06:16 AM
b16acrxer's Avatar
You know what you need to do? Grow up and stop being such a smartass. You need to curb that attitude and do it quickly, it will get you nowhere fast.</TD></TR></TABLE>
hahaha. thats pretty funny...
ok by the way....my battery keeps ending up dead.... im gonna take my car to the parts store and let them do a "free complete checkup of [my] cars electrical and charging system" maybe that will lead me somewhere.
Old Jan 23, 2004 | 09:48 AM
crxtreme89h's Avatar
I am gonna say that it has something to do with relocating your battery. Check all your wiring.
Old Jan 23, 2004 | 09:59 AM
Built Beast's Avatar
Default Re: shoo wee doggies! my b16a swap doin some wierd stuff (tim_adams85)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tim_adams85 &raquo;</TD></TR><TR><TD CLASS="quote">Hahaha, I have a similar situaton.... every once in a while, when making left hand turns, my dome light will turn on, then off again once I straighten the wheel. I too have a b16a swap, just in a civic dx. I figured it was a jdm thing y0! </TD></TR></TABLE>
funny ****...
Tiirnako
Feb 13, 2019 04:38 PM
bodiez
Jul 4, 2007 09:56 PM
I3ackfire
16
Mar 25, 2004 06:47 AM
TheHatchHog
May 9, 2003 10:30 PM
Tru Dynamix
10
Jul 11, 2002 10:25 AM
