right rear shock coming loose?
Old Dec 30, 2003 | 09:11 AM
narib2001's Avatar
Default right rear shock coming loose?
for 5 months now i have had my suspencion setup done on my car.Im happy with it just that when i go over a bump the right rear shock makes noice like stuff is loose in my trunk.Makes this noice alot,also when i turn too the right some times i have a noise kinda sounds like a bar holding the suspencion is flapping around or something.Kinda weird.Has this happend too anyone before?Anyone know how too fix it?
Ricey McRicerton's Avatar
Default Re: right rear shock coming loose? (narib2001)
Have you checked to make sure it's not loose?? Suspension noise is common, but I don't have it the way you are talking about.
Old Dec 30, 2003 | 09:22 AM
monicle's Avatar
how slammed is your car? if you have it really low and youre using a coilover sleeve setup, then your shock can actually travel to the point where your spring is just floating between the perches and you can get some ratteling sound that way. if your car is pretty low try raising up the rear end a bit and see if that fixes it.
Old Dec 30, 2003 | 09:36 AM
CleenSi
Guest
Posts: n/a
Default Re: right rear shock coming loose? (Ricey McRicerton)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Ricey McRicerton &raquo;</TD></TR><TR><TD CLASS="quote">Have you checked to make sure it's not loose?? Suspension noise is common, but I don't have it the way you are talking about.</TD></TR></TABLE>
take it off and check if it aint lose on the top...if it is i think you'll need a 12mm and and alan wrench.
Old Dec 30, 2003 | 02:34 PM
No's Avatar
No
i have neuspeed race witg kyb agx shocks
i think i should take it off and check it
Old Dec 30, 2003 | 03:33 PM
gc92cvc's Avatar
i have kyb agx too and my right rear does the same its almost like a squeaking noise.jst check make sure nothin is loose.
Old Dec 30, 2003 | 09:57 PM
hayabusa160's Avatar
Default Re: (gc92cvc)
would you happen to have an ek hatch by chance? my friend's hatch dose the same. once we swaped the springs
JTaudio0212
Suspension & Brakes
Oct 1, 2008 01:14 PM
Crono139
Sep 2, 2006 01:42 AM
ZipTieGUy
Mar 8, 2006 10:24 PM
Slow
Dec 17, 2003 11:40 PM
justininhifi
May 1, 2003 06:03 PM
