Prop Valve Question....
I'm about to upgrade the front brakes of my 92 vx to 95 GSR's, but for now leaving the rear drums of the vx. My question is which prop valve should I use? I'm going to be using an RS master cylinder and brake booster combo. I also have a prop valve for an Integ as well as the VX one of course. Any advice would be appreciated. TIA
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Johnny76 »</TD></TR><TR><TD CLASS="quote">I'm about to upgrade the front brakes of my 92 vx to 95 GSR's, but for now leaving the rear drums of the vx. My question is which prop valve should I use? I'm going to be using an RS master cylinder and brake booster combo. I also have a prop valve for an Integ as well as the VX one of course. Any advice would be appreciated. TIA</TD></TR></TABLE>
If you are keeping the drums on the rear then you should not change the proportioning valve. The only time it should be changed is if you will be changing the rears to disc. If you change the valve to the Integra one while using the rear discs, it will severly alter your braking balance.
89efDUSTY
13
Mar 26, 2007 11:20 PM
redsikiller
Nov 8, 2005 03:58 PM
