help! starter wont turn sometimes car wont start!
Old Dec 29, 2003 | 10:16 PM
HybridGSR1's Avatar
Default help! starter wont turn sometimes car wont start!
I've got this weird problem, usually in the morning or when its cold ..the car wont start... the starter would not turn.. and after about 10 cranks or so the starter turns and car starts.. now its happening more frequently, even when car is warm...Somone told me that the ground for starter might be lose, if thats the case could someone post a diagram of the starter and possibly where the ground is... that i should be checking for. The battery is good since all the radio and lights work fine. Thanks in advance!
Old Dec 29, 2003 | 11:21 PM
scrap1ngsr's Avatar
Default Re: help! starter wont turn sometimes car wont start! (HybridGSR1)
I had the same problem with mine and I replaced the distributor wires and spark plugs and know it just starts right up
Old Dec 30, 2003 | 12:57 AM
HybridGSR1's Avatar
Default Re: help! starter wont turn sometimes car wont start! (CivicSiR94)
why would the spark plug and wires affect the starter?
Old Dec 30, 2003 | 01:23 AM
JjuuN R's Avatar
they wouldn't, but not enough spark could keep your car from turning over, you don't know that it's the starter
Old Dec 30, 2003 | 01:26 AM
DsITR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by HybridGSR1 &raquo;</TD></TR><TR><TD CLASS="quote">The battery is good since all the radio and lights work fine. Thanks in advance! </TD></TR></TABLE>
AFAIK it takes less power to run the radio/lights than to turn the starter.
you may wanna check you battery, or try jump starting it initially just as a pre-check.
someone correct me if I'm wrong
Old Dec 30, 2003 | 03:53 AM
Asahi's Avatar
Default Re: help! starter wont turn sometimes car wont start! (DsR)
I had this problem and as shocking as this sounds . . .it was the strater. Pull the strater and try starting the car. Does it spin freely? Mine would click but not spin. Replaced and it works perfect.
Trey
Old Dec 30, 2003 | 12:16 PM
GSR-T-'s Avatar
mine does the same thing ever since i put a new distributor on....I think its just my timing
Old Dec 30, 2003 | 04:07 PM
HybridGSR1's Avatar
Default Re: (JUN.R)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by JUN.R &raquo;</TD></TR><TR><TD CLASS="quote">they wouldn't, but not enough spark could keep your car from turning over, you don't know that it's the starter</TD></TR></TABLE>
the starter wouldnt even make any sounds not even clicks sometimes...
Old Dec 30, 2003 | 06:30 PM
MK Ultra's Avatar
Default Re: help! starter wont turn sometimes car wont start! (Asahi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Asahi &raquo;</TD></TR><TR><TD CLASS="quote">I had this problem and as shocking as this sounds . . .it was the strater. </TD></TR></TABLE>
Me too. Starters are an item that seem to fail rather soon on 3rd generation Integras, along with brake master cylinders. I only had 90,000 miles or so when both started acting up on my car.
Old Dec 31, 2003 | 12:06 AM
dcdc894's Avatar
Hi, I'm an automotive technitian by the way..I have repaired many of this type problem.....hope I can give you some ideas...
First: identify your problem, when the problem is acting up, when you come across the problem which you cannot crank over the engine after couple of times trying, get a friend to give you a hand.
Firstly hold your key in the STARTING position and hold on and dont let it go, then call your friend to get anything with a bit of weight like hammer, call him to tap the starter, (avoid hitting the two external wire terminals, hit the starter body) if after hitting you engine cranks over then you have yourself a starter contact fault just like any other cars... the copper contacts in the starter solenoid gets worn after years of usage, most of the time by hitting or gentle tapping the starter body you can probably get the electrical contacts to work better than it is due to the vibration that tapping or hitting causes.....
If engine cranks over then you can start removing the starter to get a proper electrician to have a look at, usually its not expensive to have those starter solenoid contacts replaced... but there is a bit involved in this small rebuild so you better ask for the electrician's help after you have removed the starter (note: this is a simple way to diagnoise is your starter is playing up and its relatively simple to do) give it try and with you the best in getting the problem sorted...
Old Jul 13, 2004 | 02:16 AM
RAI 76K's Avatar
Default Re: help! starter wont turn sometimes car wont start! (dcdc894)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rai 76k &raquo;</TD></TR><TR><TD CLASS="quote">http://www.engrish.com</TD></TR></TABLE>
My starter went out, now I'm stuck riding the short bus...
Exempt
Aug 26, 2005 01:00 PM
98gsrTEG
Aug 1, 2005 06:30 PM
lowblazin
Nov 25, 2003 10:00 AM
elpermgrande
Aug 9, 2002 06:43 AM
