My car is blowing black stuff out of exhuast, help please?
Well the past week my car has been spitting black sute, not smoke, out of the exhaust, mainly when i start in up in the mornings, but it does it all day just not as bad. It smells like its running rich but i have not clue how to even determine the problem, im new to honda, i just work on old school volkswagen's. So if anyone could give me an idea of whats wrond and how to fix it, you would save me alot of time and money, thanks.
Modified by Wes90civic at 9:45 PM 12/29/2003
what do u mean by black stuff? u mean black smoke? if its that then most likely its that ure burning oil... i had the same problem ( bad gaskets)
im not totally dumb, i know it running rich, but when i say black sute i mean it. It left a 2 ft by 1ft dark *** spot in driveway this morning. And my main question is what i do to fix the problem, i dont know how to adjust the mixture.
I've never heard of running rich to actually leave soot like your describing. Usually it just dissapates into the air. It sounds to me like you've got an *** load of buildup in your exhaust. Possibly a very dirty cat.
Cat cant be dirty, it been hallowed out, like i said i know it running rich, but the sute stuff that blows out is worrying me a bit, i wonder if i have some kinda senser out? not sure
mine did that.. but it smoked white cuz the rings were cracked.. and it was burning oil like a mother. first things first.. are you burning oil?.. are you sure its not smoking? have someone follow behind you while your on WOT.
if thats not it.. hows your gas milage?.. if its **** then yeah proably an o2 sensor going bad.. stuck injectors.. bad gas
gas milage ok?.. bad gas.. umm, dirty as hell fuel filter.. but doubt it??.. i dun no its proably and o2 sensor tho
it is most likely condensation. or water in your exhaust, and then it turns black because of the exhaust fumes. go run your car on the highway so it cleans out your pipes and drys it out. see if that helps at all.
Hey man, i had that same problem wif my crx, it was becuase my coolant and oil had mixed. it really messed my system up, and it leaves a black residew in my exhaust - it was dirty.
better get it checked
Well i had a friend follow me and it is blowing some smoke, only when i get on it, and today it started to overheat some, so i stopped waited a bit checked my radiator, it was like less than half full or more, it took alot of water to fill it, but the weird thing is i dont have any water buildup in my oil, my oil would show if i was leaking water into it. So i dont know, im not leaking any water or fluid from radiator, so i must be burning the water right? but if i am buning water how come when i check my dipstick it dosnt show any traces or water? Well im confused and i dont even know where to start, maybe i just need a rebuild or a new motor, who know, help me if you can, thanks
Wes
Wes
TrunkRattlin
May 17, 2006 11:30 PM
RallySportCivic
10
Feb 1, 2003 02:42 AM
