how to make shock sensor more sensitive?
i recenly bought a clifford alarm, and it had a shock sensor, before they installed it, i noticed that the shock sensor had a little **** on it that you can turn. can i just turn that **** to make the sensor more sensitive or something? if not, then how can i make my sensor more sensitive?
well i know most DEI's have the little **** you can turn. and clifford is a DEI alarm, i forgot which way i had to turn mine but you should be able to turn it up
which model is it?
which model is it?
look to the right of the remote, that little box, there is a **** at the end of it. is that the **** to make it more sensitive? if so, does anyone know where it might be located?? and another thing, i just noticed today that whenever i turn my car off, my alarm "beeps" 2 times, but i haven't even touched the remote yet...why is it doing this??
it will usually be under the steering column. or it will by tied down to something and not loose. and will have a little **** on it.. and just turn it all the way clock wise
