90 integra ls cluster
how do i take off the cluster off my integra ls? i used to own a EF and it was quite simple, but the integras seem to be a little more difficult.
You have to remove the bezel that goes around the center vents, switches (foglight,cruise,sunroof,ect.) There are 5 screws that hold it in. You will need to remove the switches frome the bezel. After that there will be two screws at the bottom of the cluster that hold it to the dash. Be caruful when pulling the cluster out it is easy to damage the speedo cable. There are also three wiring harness clips on the back of it (2 on the left side and 1 on the right). Then it should come right out.
