i got an rc injector question
Old Dec 28, 2003 | 09:16 PM
eg_type_r93's Avatar
Default i got an rc injector question
hey just bought these 310cc injectors like these
and they wont fit into my itr manifold
what should i do they are to fat in the bottom
grind down the itr manifold is what i thought would this be ok?
thx
Old Dec 28, 2003 | 09:19 PM
b19coupe's Avatar
Default Re: i got an rc injector question (eg_type_r93)
They fit fine in my ITR manifold-you just use the o-rings provided by RC, instead of the stock ones.
Old Dec 28, 2003 | 09:24 PM
Default Re: i got an rc injector question (b19coupe)
how hard did you have to shove the injectors in, or did they just slide in cause mine arent?
i guess thats my question
their obd1 injectors and its an obd2 manifold this should not matter right
Old Dec 28, 2003 | 09:31 PM
b19coupe's Avatar
I am running RC 310's in my ITR. OBD1 injectors-had to rewire them-in an OBD2 car. RC sells clips to do this as well. As far as shoving them in, just make sure that they are centered, and tighten the three 10mm nuts on the fuel rail until the nuts bottom. Then turn the key on (not start) to pressurize the fuel rail and check for leaks.
Old Dec 28, 2003 | 11:03 PM
hondaboyB18C1's Avatar
coat the orings with some lube it helps them slide in i have them in my ITR intake with the OEM orings
Old Dec 29, 2003 | 12:32 AM
MyBigNut's Avatar
Could you post pics of your stock injectors?
Reason I ask is because I recently saw some Accord Type R injectors.. and they're a lot smaller than the injectors we have here in the US.
Also, is that picture you posted the actual injector you have? I've seen RC's, and the ones I've seen have different widths throughout the injector.
Example
The one I'm talking about is 2nd from the right.
Old Dec 29, 2003 | 01:16 AM
will post up pics tomorrow
Old Dec 29, 2003 | 05:52 AM
rolow's Avatar
Default Re: (eg_type_r93)
They fit very snug. I used the method b19coupe suggested I also lubed up the o-rings
gnxpro24
Jun 15, 2015 07:09 PM
JDM_Ej
Aug 8, 2005 12:32 PM
Franky
Aug 25, 2004 12:30 PM
magic hat #9
Apr 22, 2004 08:19 PM
