b16 swap how-to?
https://honda-tech.com/zerothread?id=550976
good luck
b18c5-eh2's post about 5 or 6 down is very helpful, and a couple of posts after that
good luck
http://www.c-speedracing.com/h...p.php
http://www.hondaswap.com/swap/civic/five.php
is searching too hard for you?
thanx ...... i think im gettin in over my head with tryin to do this swap alone....oh well itll be a learnin experience if anything along with some gray hairs.....
took me two hours just pull old motor with a lift. put new engine on lift line motor mounts up. Then drop new motor in. Last hook all the loose ends up. Finally slam hood shut and your done.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RedLine_Performance »</TD></TR><TR><TD CLASS="quote">took me two hours just pull old motor with a lift. put new engine on lift line motor mounts up. Then drop new motor in. Last hook all the loose ends up. Finally slam hood shut and your done. </TD></TR></TABLE>
yep that about sums it up. plug it up, add coolant and drive.
thanx fellas im stoked on this project.......hopefully it all goes as smooth as it sounds.....i might be comin back to u boys for help if **** goes wrong
......thanx
......thanx
hangoncaroline
Sep 5, 2004 08:03 AM
