b16 swap how-to?
Re: b16 swap how-to? (HUBB)
https://honda-tech.com/zerothread?id=550976
good luck
b18c5-eh2's post about 5 or 6 down is very helpful, and a couple of posts after that
good luck
http://www.c-speedracing.com/h...p.php
http://www.hondaswap.com/swap/civic/five.php
is searching too hard for you?
Re: b16 swap how-to? (Jswpstdoff)
thanx ...... i think im gettin in over my head with tryin to do this swap alone....oh well itll be a learnin experience if anything along with some gray hairs.....
Re: b16 swap how-to? (GERM)
took me two hours just pull old motor with a lift. put new engine on lift line motor mounts up. Then drop new motor in. Last hook all the loose ends up. Finally slam hood shut and your done.
Re: b16 swap how-to? (RedLine_Performance)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RedLine_Performance »</TD></TR><TR><TD CLASS="quote">took me two hours just pull old motor with a lift. put new engine on lift line motor mounts up. Then drop new motor in. Last hook all the loose ends up. Finally slam hood shut and your done. </TD></TR></TABLE>
yep that about sums it up. plug it up, add coolant and drive.
Re: b16 swap how-to? (rewsnaeht)
thanx fellas im stoked on this project.......hopefully it all goes as smooth as it sounds.....i might be comin back to u boys for help if **** goes wrong ......thanx
hangoncaroline
09-05-2004 08:03 AM
