wtf is going on with my car!
Old Sep 24, 2001 | 08:44 PM
Chris_'s Avatar
Default wtf is going on with my car!
ok so I just got my PR3 ecu today. and Im running into some problems first code 6 but I already have that problem figured out (almost) the nest is when I am just chillin in 5th crusing my car feals like it is going to bog out and stall.. if I give it a little more throttle it goes back to normal but If I am trying to maintain a stedy speed it gets all bogged out like it is not getting enough fuel.. any Idea what that could be.. Im not sure if I explained it well....
Old Sep 24, 2001 | 08:52 PM
PrjR Rex's Avatar
New User
Default Re: wtf is going on with my car! (crxconnection)
Distributor, Cap, Rotor. TPS. Injectors. Most common problems with something related to this problem, as far as I've seen.
Old Sep 24, 2001 | 09:25 PM
Chris_'s Avatar
Default Re: wtf is going on with my car! (PrjR Rex)
thnx
Old Sep 25, 2001 | 07:02 AM
kahren's Avatar
check your timing belt if its on there right TDC and all that and make sure your timign is right 18 degrees or so
carlthecrx
Feb 6, 2008 08:34 AM
mckrank313
Sep 23, 2007 08:14 PM
Ash81
Feb 3, 2006 01:43 PM
Kevin Type Si
May 24, 2004 11:35 AM
vsual
12
Dec 10, 2001 02:45 PM
