foglights done!! check it out
Old Dec 28, 2003 | 06:46 PM
tekstyle's Avatar
Default foglights done!! check it out
i used dupli sandable black primer and top clear coat to prevent it from rusting. i shouldve used caliper paint cuz of the heat and then apply the primer on top of that. o well. dun really feel like doing it again now that its done. cut off is perfect so it should go under the fog real nice.
[IMG][/IMG]
u might need to Rclick the link, go to properties and copy the addy. then paste into a new window to see it.
before pic.
Modified by tekstyle at 6:07 AM 12/29/2003
Old Dec 28, 2003 | 07:02 PM
rufridn's Avatar
Default Re: foglights done!! check it out
Old Dec 28, 2003 | 08:21 PM
GSRacer93's Avatar
are those the headlight projectors?
Old Dec 28, 2003 | 08:30 PM
tekstyle's Avatar
Default Re: foglights done!! check it out (GSRacer93)
yup
Old Dec 28, 2003 | 09:05 PM
yAtch's Avatar
Default Re: foglights done!! check it out (tekstyle)
looks nice... cool lip
Old Dec 28, 2003 | 09:10 PM
NA gs-R 05 C
Guest
Posts: n/a
not bad at all.
Old Dec 28, 2003 | 09:11 PM
B2FiNiTY's Avatar
wow... want to teach us? Black housing headlights correct?
Old Dec 28, 2003 | 09:17 PM
tekstyle's Avatar
Default Re: foglights done!! check it out (B2FiNiTY)
integra projectors sprayed black. kinda hard to make a tutorial since its just a lot of cutting away as much of the grill and the metal housing as much as possible to fit the thing in there. but one thing, a lot of custom drilling and fitting and trial and error. i'll try to make a tutorial for it, but the best i can do will be guidelines. not everyone's will turn out the same.
Old Dec 28, 2003 | 09:20 PM
thaiphob's Avatar
Nikon!!!
not bad!
Old Dec 28, 2003 | 09:36 PM
elwood's Avatar
Headlight out in the last pic?
Old Dec 28, 2003 | 10:25 PM
PatrickGSR94's Avatar
Community Builder
Community Influencer
Active Streak: 60 Days
Default Re: foglights done!! check it out (elwood)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by elwood &raquo;</TD></TR><TR><TD CLASS="quote">Headlight out in the last pic? </TD></TR></TABLE>
nope that's the flash reflecting off the projector.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by B2FiNiTY &raquo;</TD></TR><TR><TD CLASS="quote">wow... want to teach us? Black housing headlights correct? </TD></TR></TABLE>
Not the foglights, cuz there's no housing to paint black. His headlights have black painted projector bezels, same as what I did to my 94 headlights.
Old Dec 28, 2003 | 10:27 PM
Community Builder
Now you should stick some 9005's in those projectors.
Old Dec 28, 2003 | 10:54 PM
XtremeCarTuner's Avatar
holy chit that looks nice. Definately if i do the project, i should use some high temp spray. I wouldn't want that chit burning inside my headlight assembly....
Old Dec 28, 2003 | 11:29 PM
tekstyle's Avatar
Default Re: (XtremeCarTuner)
here's the install process.
https://honda-tech.com/zerothread?id=717807
Old Dec 28, 2003 | 11:35 PM
Sukebei Oni's Avatar
Default Re: (tekstyle)
looks nice at night. got any day pics?
Old Dec 28, 2003 | 11:37 PM
tekstyle's Avatar
Default Re: (Sukebei Oni)
naw, i just finished it today and it was night time by the time i finished it.
Old Dec 29, 2003 | 11:01 PM
GSRacer93's Avatar
props... looks very nice... how's the beam pattern look from inside the car?
Old Dec 29, 2003 | 11:17 PM
tekstyle's Avatar
Default Re: (GSRacer93)
looks like an extra set of headlights but mounted lower. i see more of the road than with the foglights i had before, but i m using HID for my low beam. it might have made a bigger difference if i was using stock bulbs for my low beam instead.
Old Dec 29, 2003 | 11:58 PM
slowguy's Avatar
nice, but have you ever got pulled over for those headlights?
Old Dec 30, 2003 | 01:39 AM
tekstyle's Avatar
Default Re: (slowguy)
nope
Old Dec 30, 2003 | 07:02 AM
EXOSPEED:SHARK's Avatar
From: Azusa,CA USA/ Manila Land of the Pick Pockets
damn your HID's werent bright enough?
Old Dec 30, 2003 | 09:08 AM
youngkow's Avatar
That looks very very nice!
Old Dec 31, 2003 | 02:29 AM
tekstyle's Avatar
Default Re: (youngkow)
tonight, i came back from watching last samurai.. good movie.. but so sad. anyways.. i was driving in the fog. i was satisfied about how my foglights turned out. they sure do light up the road. they dun light up the fog, but the road ^^. along with the HID, it turns night into day!
NOTE: i bet you can imagine how thats gonna be with high/low/fogs all on at once.... hahha *rally car*.. but it sure does light everything up.
Ep1dem1c
Paint and Body
70
Jan 6, 2008 10:00 PM
DaveF
Mar 15, 2007 10:40 PM
stewie8apie
Jul 22, 2006 10:52 AM
UNDER PRESSURE
Jun 16, 2004 04:33 PM
ea_hatch
Apr 24, 2004 09:51 AM
