Weres the fuel pump?
Old Dec 28, 2003 | 03:38 PM
Traction's Avatar
Default Weres the fuel pump?
were exactly is the fuel pump located on a car?
No I dont have a car or Id go and figure it out. Just wonderring were it is for a 2nd gen crx.
Dam this is a noob question
Old Dec 28, 2003 | 03:42 PM
91civicEX's Avatar
Default Re: Weres the fuel pump? (StealthEF)
on top of the gas tank.
Old Dec 28, 2003 | 03:43 PM
88DXCRX's Avatar
From: I told you to wait in the truck in Texas, United States
convienently located in the gas tank..
On A 2nd gen crx you have to drop the tank..
Old Dec 28, 2003 | 03:56 PM
Traction's Avatar
Default Re: Weres the fuel pump? (88DXCRX)
seriously, the tank has to be dropped to splice into the positive yellow wire?
dammit
Old Dec 28, 2003 | 03:59 PM
FourthGenHatch's Avatar
If you remove your backseat under it there are wires going to the fuel level sender and probably the fuel pump since I never saw any wires on the underside of the car.
Old Dec 28, 2003 | 04:03 PM
DumpedSi's Avatar
Default Re: Weres the fuel pump? (FourthGenHatch)
no, if you're trying to do a fuel pump cut off switch you do not need to take the gas tank out, take out the rear storage compartment and you should be able to acess the wires from there. There will be a metal plat with 4 screws I believe remove that and theres your fuel pump
Old Dec 28, 2003 | 04:27 PM
another_crx's Avatar
Default Re: Weres the fuel pump? (Slammed Si)
thinking of doing the same thing myself
the 2 wires will be black and yellow right?
My rear is gutted so I should be able to find the plate easily. Will there be any other wires other than the yellow/black? dont wanna **** up if there not yellow/black
Old Dec 28, 2003 | 08:13 PM
Default Re: Weres the fuel pump? (another_crx)
just looked in my manual, is the pump right in the middle just behind the pass/driver seats or just the electrical?
Modified by another_crx at 5:36 AM 12/29/2003
A-dub5513
Apr 15, 2010 04:28 PM
puertoricanboy90
Dec 26, 2008 03:41 PM
sssimmon
Feb 26, 2006 08:13 PM
boylovecar
Dec 3, 2005 12:36 AM
