ECU Immobilizer reprogramming (K20A2 swap related)
Old Dec 28, 2003 | 02:53 PM
Big Si Guy's Avatar
Default ECU Immobilizer reprogramming (K20A2 swap related)
In a couple days a K20A2 swap will be going into my 03' Si.
I know that I need to use the A2 ECU (of course) and will need to get it programmed to work w/ my immobilizer. I have had this done in the past by a friend who is a honda tech, back when i bought a used Hondata ECU.
My question is:
With this re-programming, is he programming the new ECU to work with my immobilizer, or is he programming my immobilizer to work with the new ECU?
The reason I ask is because I need to know if, after the A2 swap, will I have to drive to the dealer on the A3 ECU (will that even work?) then swap to the A2 ECU and have it programmed, or can I take care of that ahead of time?
Sorry, I know the wording's a bit confusing, but any help is appreciated.
T.I.A.
---Adam---
Old Dec 28, 2003 | 05:02 PM
dgonzals's Avatar
From: The Land Of Car Thieves/Rising Gas Prices Daygo, CA, US
Default Re: ECU Immobilizer reprogramming (Big Si Guy)
i dont know...but i would like to know...does someone know?
Old Dec 29, 2003 | 06:52 AM
B18CXr's Avatar
yes and yes
Old Dec 29, 2003 | 07:24 AM
bluesiTYPER's Avatar
Default Re: ECU Immobilizer reprogramming (B18CXr)
Per above, yes it works w/the A3 ECU..the immobilizer system has to do with your key, your immobilizer unit in your car, and your ECU..they will be reprogramming the A2 ECU to your unit and key..
Old Dec 29, 2003 | 08:06 AM
GreenR's Avatar
Will a Type-R ECU work on a Type-S?
Old Dec 29, 2003 | 08:12 AM
Hondata's Avatar
Or you could simply have your Civic Si ECU reprogrammed with the RSX-S hondata program. No key recoding or other ECU is necessary.
Old Dec 30, 2003 | 03:55 PM
Jim Truett's Avatar
It's all about programming with these latest generation ECUs. The immobilizer is integrated with the main board, and no longer a swappable daughter circuit board like the older OBD-2 ECUs. It will need to go to the dealer for the immobilizer code to be programmed.
mita
Aug 28, 2014 11:46 PM
stemiched
24
May 26, 2006 05:39 PM
JDM.Sleeper
Jun 9, 2005 08:05 AM
Big Si Guy
Dec 30, 2003 07:18 AM
