taking out a/c
the parts that i usually just take out are the engine compartment parts - i don't like going under the dash to rip things out - and you don't really need to anyway - but, take out the compressor and remove the belt, take off the two hoses that go to it (which i usually just use wire cutters and cut the tube near the firewall for each one), and remove the condensor infront of the radiator, oh, and the ac fan - which you could leave in if you want to and wire it in to the other fan so you have both fans. either way.
make sure you eather have a breaker bar or a pipe to extend your rachet becuase the bolts that hold the AC bracket onto the block can be a bitch
also have 2 sets of vice gips and a varity of different larger sized wrenches
96CivicEXSedan
Jul 28, 2015 03:20 PM
W0oT
Sep 21, 2001 06:39 AM
