i think i need to steal my own car.
Old Dec 28, 2003 | 12:26 PM
Filliam H. Muffman's Avatar
Default i think i need to steal my own car.
last night...i went with some friends to go watch a movie, and i didnt want to drive so i left my car at my friends house. i put the alarm on, and put the keys in my pocket.
Turns out my pocket had a FAT hole in it. so at one point or another i lost my keys. i have spare keys but no spare alarm. So I think im going to have to steal my own car...im not sure if the alarm has an immobilizer, cuz i bought it with the alarm. it looks really old, and has a really sensitive shock sensor. but i still dont know if it has the immobilizer.
i have to take the car to a shop so i can get another alarm made. so just in case the car does have the immobilizer, how the hell can i get around it?
ng's Avatar
ng
Unplug the battery and have the bitch towed.
Old Dec 28, 2003 | 12:31 PM
Jimmy's Avatar
Global Moderator
Default Re: (ng)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ng &raquo;</TD></TR><TR><TD CLASS="quote">Unplug the battery and have the bitch towed.</TD></TR></TABLE>
good idea
Btw: this is kind of a bad topic... this may attract theives to this thread lets not give give to many ideas
Old Dec 28, 2003 | 12:36 PM
cxSHOE's Avatar
Default Re: i think i need to steal my own car. (JUN EK9)
go to the brain of the alarm... you will see four wires coming out of the brain unclip it and your alarm system is now defeated... regardless of it going off...
now you know how easily the crooks steal our cars......
handa's Avatar
Default Re: (USDMDC2)
backtrack...and find your keys+alarm.
other than that...all i can think of is to hope your car doesn't have immobilizer and use your spare keys.
Old Dec 28, 2003 | 12:40 PM
Ricey McRicerton's Avatar
Default Re: (handa)
I wanna say you can order a new alarm remote..pm me for more details. I don't particularly want to start all of this info out in the open.
Old Dec 28, 2003 | 12:49 PM
coolboarder's Avatar
You can deactivate most alarms using the valet switch and your key. Usually, while the alarm is going off, you put you key in the ignition, turn it to the on position, then flip the valet switch on and off like 3 or 4 times and the alarm turns off.
Old Dec 28, 2003 | 12:55 PM
cxSHOE's Avatar
Default Re: (coolboarder)
well you only have to do it once if using the valet switch.....
thats the whole point of having the valet switch. if you loose your remote .. no alarm company will market it if you had to do it 3-4 times.....
Old Dec 28, 2003 | 12:56 PM
Default Re: (cxSHOE)
Damn, you guys are good.. I completely forgot about the Valet switch.
Old Dec 28, 2003 | 01:08 PM
TwistedSI's Avatar
You can also just use the key to get in and let the alarm go off. Pop the hood and loosen batter connection. Put the key in the ignition and turn it to Acc., unhook battery, give it a few then hook it back up. It should see that the key is in acc. and not go off. If there is a bettery backup siren it is a little trickier.
Old Dec 28, 2003 | 01:10 PM
cxSHOE's Avatar
Default Re: (TwistedSI)
that wont work since the brain will have the last entry of it being activated. regardless of taking off the battery and putting it back in..&lt;&lt;&lt; hence if the alarm has immobilizer it still wont run.??
Old Dec 28, 2003 | 02:04 PM
B18C2_sedan's Avatar
good idea<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cxSHOE &raquo;</TD></TR><TR><TD CLASS="quote">well you only have to do it once if using the valet switch.....
thats the whole point of having the valet switch. if you loose your remote .. no alarm company will market it if you had to do it 3-4 times.....</TD></TR></TABLE>
Old Dec 28, 2003 | 02:08 PM
Default Re: (B18C2_sedan)
i dont think the alarm has a valet switch, and even if it does, i have no idea where it is
Old Dec 28, 2003 | 02:28 PM
greebler's Avatar
Default Re: (ng)
WTF?
Disconnect the alarm wire from the battery, your ears might ring for a wile after.
Old Dec 28, 2003 | 03:17 PM
anarchyfox's Avatar
Default Re: (JUN EK9)
haha, is your bong still in the back? (this is aaron from the sd meet btw). sdsu memories...muahaha. saw your post and thought i'd give you a hard time...haha
anyways...just tow it somwhere man
Old Dec 28, 2003 | 03:39 PM
dantastic's Avatar
fyi.... most clifford alarms have coded 2-button valet switches; you need to punch in a certain, programable sequence. also, with most clifford alarms, if you pull the brain, the car still wont start. clifford alarms are
but back to the topic: the alarm should have some sort of valet button. just switch the ignition to II and press the button. the alarm should shut off
Old Dec 28, 2003 | 03:40 PM
rated_r's Avatar
Default Re: (ng)
Old Dec 28, 2003 | 03:51 PM
TwistedSI's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by cxSHOE &raquo;</TD></TR><TR><TD CLASS="quote">that wont work since the brain will have the last entry of it being activated. regardless of taking off the battery and putting it back in..&lt;&lt;&lt; hence if the alarm has immobilizer it still wont run.??</TD></TR></TABLE>
Ummmm, most alarms don't have a memory of this? At least none of the alarms I have ever installed. And I thought he said he didn't know what kind of alarm it is but that he knew it was an older one.
Old Dec 28, 2003 | 05:06 PM
yeah the alarm looks way old...but ill try the battery thing first...that is if the immobilizer is there.
Old Dec 28, 2003 | 05:22 PM
HATCHingMN's Avatar
take out the siren or horn
Old Dec 28, 2003 | 05:50 PM
Default Re: (HATCHingMN)
yeah...the alarm is shitty and done with....so my plans are to cut the alarm and just drive it to good guys and get the new one installed...i want to protect my investments with a good system
JDM-EJ1
Aug 7, 2006 01:41 AM
scrap1ngsr
Audio / Security / Video
22
Jun 21, 2005 03:33 PM
PlikityPLAH
Feb 4, 2005 02:29 PM
Stewie
19
Jul 14, 2004 06:04 PM
SRd240sx
10
Jul 6, 2004 07:20 PM
