b18c5 crx help
i am getting a 91 crx si and want to do a b18c5 so
i want to do everything right like
hasport maounts and hydro to cable conversion and all harness and stuff for wiring so thats it is correct
what am i gone have to do for other stuff any info is helpful
also does anybody remember the guy on here that had the crx with b18c5 and spoon calipers and other stuff thanks guys
The swap is just like a B16. Same axles, mounts, rad hoses, etc.
you can go OBD0 and use the PR3 or PWO ECU reprogrammed with something like mugen or so.
But, since you would be getting (I assume) a complete swap with hydro tranny and all, then your best bet is to go OBD1.
You can use the distributor and injectors. You would need a OBD0 to OBD1 jumper harness, and a OBD1 ECU.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by The new Spaceballs »</TD></TR><TR><TD CLASS="quote">The swap is just like a B16. Same axles, mounts, rad hoses, etc.
</TD></TR></TABLE>thats teh geh, goto http://www.pgmfi.org and look for chipping your own ecu with a custom program you can make. I'm sure some ppl on here would do it for you, i could also do it for you
after having a cable trany setup, i would go for the hydro setup. Since cable parts are not easy to find if you ever need to rebuild, just for future possibilities i would go hydro. Plus why part with what u get with your swap.
thehatch97
Oct 15, 2009 02:17 PM
hebelect
Jun 14, 2004 11:59 AM
